Question about Fuji FinePix F11 Digital Camera
Shutter opening problem
Fuji finepix f11. When press the button to turn camera on the shutter does not open. The last few times its been turned on the shutter half opened and if switched off and then back on again it would open properly but now it just won't open at all. Will I have to take it to repairers and will it be a cost effective repair?
  • sideeq_kt Jul 15, 2008
    fuji finepix f11. When press the button to turn camera on the shutter does not open. The last few times its been turned on the shutter half opened and if switched off and then back on again it would open properly but now it just won't open at all. Will I have to take it to repairers and will it be a cost effective repair?
    have you FUJI E550 fine pix service manual of free chagre ,If you have please sent to me by my email.
How hard did you press on the button? it will focus if not all the way. Also, check your battery. Other than that, I don't know.
Posted on Jul 10, 2008
How doI set up f11 on this camera
Do you mean set the aperture at f/11?
If you want the camera to set the shutter speed for proper exposure, turn the mode dial to the A position for Aperture Priority. Press the +/- button to display the shutter speed and aperture. Press cursor-up/down to change the aperture and the camera will change the shutter speed to give the proper exposure.
If you want to set the shutter speed and aperture yourself, turn the mode dial to M for Manual. Press the +/- button. Press cursor-up/down to set the shutter speed, cursor-left/right to set the aperture.
Full details are in the Shooting Mode section of the manual.
Nov 17, 2013 | Fujifilm FinePix S4250 Black 16MP Digital...
How do I change the shutter speed on the Fuji S8000fd
Set the camera to Shutter Priority AE by turning the mode dial to S. Press the +/- button to open the setting screen, then press up/down to select the shutter speed.
You control the shutter speed the same way in Manual mode. You also select different shutter speed/aperture combinations the same way in Program mode.
You can indirectly control the shutter speed in Aperture Priority AE by changing the aperture and letting the camera set the appropriate shutter speed.
May 27, 2010 | Fuji FinePix S8000fd Digital Camera
I often miss a shot because there seems to be a delay when I press the shutter button on my Fuji FinePix A350 digital camera. Is there a setting I can change to speed up the process?
It's called "shutter lag"...a common problem with all point and shoot cameras. To avoid it, press the shutter button half-way and allow the camera to lock in the focus (it will beep) before pressing the rest of the way.
Jan 03, 2010 | Fuji FinePix A350 Digital Camera
Shutter speed on the auto mode of my s1000 camera seems slow. how can it be increased in the auto mode? This is a Fuji camera and by the time I press the shutter button subjects have moved. I have set the...
You need to press the shutter button half-way and allow the camera to lock in the focus before you press the rest of the way. This eliminates "shutter lag".
Dec 30, 2009 | Fuji FinePix S1000FD Digital Camera
Fuji FinePix F30 shutter problem: won't take pictures
Its fairly easily fixed and its a common problem with the F30. The shutter button contact slides off upon impact when dropped, it must be re-aligned so that it makes proper contact and performs normally. All that is needed is the special screw driver for the F30 (easily purchased online, just google it: "screw driver for fuji f30" ) or bring it to your local watch/jewelry repair store and tell them to open it up for you.
We have two F30's and they both have been dropped, both did the same thing with the shutter button. But both were easily fixed. Always keep the camera in a safe place and away from kids, they are very sensitive devices. Use the wrist cord when taking photos.
Nov 19, 2009 | Fuji FinePix F30 Digital Camera
Fuji FinePix A820 Won't reset
To solve this problem you need to use the SP shooting mode.
Replace battery with new High power ones. and switch ON keeping pressed the PLAY Button.
If still does not retract disable the flash and repeat the operation without the XD/SD Memory Card inserted. It will then close the shutter magic.
Regards,
PDG
Jun 19, 2009 | Fuji FinePix A820 Digital Camera
Deleting pictures one at a time
turn the power on from the back. do not open shutter. press middle button menu/ok. the first selection to come up is the erase option framed in orange. there will be a trash can at the bottom. then use the button in between the zoom buttons to highlight the frames or all frames option then press ok. that should do it for you.
Jan 01, 2009 | Fuji FinePix A340 Digital Camera
Suddenly turning off...
all figured out,,,,the shutter button is too close to the shut off button,its happened to me many times ,next time it happns try to catch yourself and see which button you pressed,,guaranteed!!! it sucks
Apr 20, 2008 | Fuji FinePix A345 Digital Camera
Repair Fuji F30 shutter button does not work, case damaged
I also dropped my Fuji F30.
The half-press of the shutter didn't work anymore.
I bought a triwing / triblade screwdriver (about 5 euros) to open the case.
The flatcable running from the knobs on top of the F30 to the main print was a bit loose. After reconnecting it, the shutter button was fully functional again.
It seems that from the backside the most 3 three wires in the flatcable are for the shutter, so if your cable is also a bit loose, this might solve the problem.
NB Remember to only open the backside of the casing, there is no need to open the lens-side. Opening and closing the backside is really easy and could be done by anyone with the right tools. (read screwdrivers...)
Oct 28, 2007 | Fuji FinePix F30 Digital Camera
Fuji FinePix F11 Digital Camera Logo
143 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
