Question about Schwinn Mesa GSD Men's Mountain Bike
I would like to service my Schwinn Mesa, Is there a manual? If not what needs to be done for a general service?
  • 75 Answers
Check, clean, and lube all the brake and shifter cables. Check and possibly replace brake pads. Check for any play in the headset ( this is the tube that carries the bearings for the handlebars and front fork ). Clean and lube the chain, gears, and derailers. After all of that just check the torque on all the hardware and make sure nothing is coming loose.
Posted on May 31, 2010
What kind of bike is this U01045666
Its a Schwinn made in China around 1995
Sep 09, 2014 | Schwinn Mesa Gs Mountain Bike
Using Schwinn bike pump
the piece that goes on the valve stem unscrews and then you turn the inner rubber piece to fit the other type of valve
Jun 04, 2013 | Schwinn Mesa Gs Mountain Bike
What size seatpost fits the schwinn mesa gsd? what size seat clamP? what size front derailuer? what size bottom bracket?
As this example shows, they don't publish all of those variables...
http://www.bikepedia.com/quickbike/BikeSpecs.aspx?Year=2004&Brand=Schwinn&Model=Mesa+GSD&Type=bike
Ask Schwinn.
http://www.schwinnbikes.com/contacts
1-800-626-2811
The year it was made might affect the answers. Ever seen this before - "*All prices and specifications are subject to change without notice."
Jul 06, 2011 | Schwinn Mesa GSD Men's Mountain Bike
Trying to get the crank set off of the shaft. I have the dust cap off, Im not sure about the nut i guess. Does it take a large allen wrench and twist out? I have a Mesa Gs
after u take off out the bolt ( or nut) ,you need a specialty tool that screws into where the dust cap was then you tighten the bolt in the center..and it pulls it off the crank...they were about $10 thirty years ago, not sure about now good luck
Jun 16, 2011 | Schwinn Mesa Gs Mountain Bike
I have a Schwinn "95 Mesa GS. Looking for
If these are replaceable than you would you have to look it up by the brand of shocks.
Ex. Rockshocks Duke 1995. The replacement parts are specific to the make/ model and year. All the shock companies have a customer service messaging service so they can you give you advice on your particular shock.
Jan 10, 2011 | Schwinn Mesa Gs Mountain Bike
Rusted chain and gears, rusted brake lines, cracks in brake pads
There is no quick fix, you need
new chain and gears
new brake lines
new brake pads
to stay safe
Jun 02, 2010 | Schwinn Mesa Gs Mountain Bike
Bad crank bearings can move crank arms small amount.
That would depend on the style of bearings (loose ball or caged balls vs sealed bearings) and possible bottom bracket damage.
Either way, a Bike Shop mechanic would probably need to assess it for you. Special tools are usually involved.
http://parktool.com/repair/byregion.asp?catid=61
May 23, 2010 | Schwinn Mesa Gs Mountain Bike
How to disassemble crank bearing on Schwinn Mesa Mountain Bike
You wil need a couple of special tools, or be fairly creative with the tools you have.
  1. remove the dustcovers in the crank arms at the crank axle
  2. loosen the crank retaining nut/bolt.
  3. thread in a chank puller and pull the crank arms.
  4. remove the lock ring on the adjustable side of the crank axle (Requires lock ring wrench)
  5. remove adjustable bearing cup.
  6. remove axle and bearings
  7. replace or repair as needed.
Once you have it opened up ou can determine if you need new bearings or crank axle.
to assemble, reverse above procedure, insuring bearing play is minimalized.
Hope this helps.
Ed
Apr 16, 2009 | Schwinn Mesa Gs Mountain Bike
Schwinn Mesa GSD Men's Mountain Bike Logo
343 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
