Question about Car Audio & Video
Dowload operating instructions phillips 22rc220/35 car stereo
Can anyone help me find operating instructions for a phillips 22rc220/35car stereo. It works to a degree so I am not looking for an unlock code just the user instructions.
Many thanks
DrElectrics
  • 199 Answers
SOURCE: Car stereo unlock instructions
Look in the manual, it will give instructions.
I think you turn stereo on, it will ask for code and you push and hold menu.
Posted on Feb 13, 2008
SOURCE: Need a code for my Sony CDX-GT210...
If you in fact bought the car WITH the strereo in it and the steareo is not how you SAY stolen!?!? then it would have come with a little card that has the PIN on it. Else you can show your car invoice to the dealer and he can request a new one from the manufacturer. If it is stolen then you well. you get what you pay for. =)
Posted on Jun 28, 2008
  • 110 Answers
SOURCE: 97' jeep cherokee car stereo instructions in german !!!!!! Help
good morning
you can check out
www.mobileinformationlab.com
this website has lots of wiring diagrams and manuals
if no help there then go to local jeep chrysler dealer and go to parts dept they can order you a new manual from dealer, you might even get lucky and find a 97 on the lot with manual still in it. good luck and let me know what you find out, not sure if i still have my manual or not i also have a 97 grand cherokee. i might be able to help a bit more.
Posted on Mar 07, 2009
SOURCE: KENWOOD KDC-1020 user manual desperately need a user manual for my wife thank you
Mate go here http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man the kdc 1023 manual is the same and its a free PDF download :)
Posted on Mar 14, 2009
  • 4848 Answers
SOURCE: CLARION ADZ628R STEREO UNLOCK CODE
To reset , leave SWITCHED ON ...UNDISTURBED for up to 24 hours
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
T
If not then it will only be available from your Main Dealer or a Decoding
Posted on Sep 06, 2009
Tip
How to install Radio in Honda Accord
Things You'll Need:
* Stereo
* Wiring harness
* Dash kit
* Phillips screwdriver
* Heat shrink
* Lighter
* Wire strippers
* Wire caps
In order to install A Radio first follow steps of Removing the Factory Radio
#1
Open the center console, and you'll see two phillips screws at the bottom. Unscrew both of them.
#2
Remove the drink tray, and unscrew three more phillips screws. The center console is now loose enough to move.
#3
Pull the center console back a few inches to expose two more screws under the plastic part of the gear shift. Remove these screws.
#4
Pull the ashtray out of the dash, and you'll see one more phillips screw. Remove this screw and pull off the plastic panel around the factory stereo.
#5
Locate the metal tray under the factory pocket (below the stereo), and pull it out of the dash. There will be two phillips screws holding it in place; remove those, and then pull the stereo out of the dash. You'll need to unplug the wiring harness that is plugged into the back of the radio.
Now Install The New Stereo
#1
Assemble the dash kit, as shown in the instructions. Put it into the dash where you just took the stereo out. There will be a rectangular opening, and a pocket underneath. The opening is where the radio will go.
#2
Secure the dash kit by screwing in the one screw in the ash tray, and the two in the opening of the panel.
#3
Insert the metal cage that came with the stereo into the opening above the pocket. Ensure that the fit is flush with the pocket. Using a screwdriver, bend the metal tabs upward, which holds the metal cage in place.
#4
Start wiring the stereo harness to the wiring harness. Match wires color by color until all of the wires are paired. For example, if you find a purple wire coming out of the aftermarket wiring harness, plug it into a purple wire from the factory harness. You aren't touching any of the wires in your dash on this step, you are simply wiring the new stereo to the wiring harness.
To connect these wires you'll want to place a piece of heat shrink over one of the wires, strip the ends, twist both ends together, and then pull the heat shrink over the exposed metal parts of the two wires. Heat the heat shrink with a lighter until it shrinks and forms a tight bond between the two wires. When done correctly, you won't be able to pull the wires apart.
#5
Plug the aftermarket harness into the factory plug, and insert the radio back into the dash. If you find wires that don't have a match, be sure to cap them so that the ends aren't exposed. Exposed wires are what cause shorts and electrical problems.
#6
Work in reverse order to put the dash back together. The radio won't be secure in the dash until the dash is put back together.
Hope this helps
Thanks
on Oct 07, 2010 | Honda Accord Cars & Trucks
1996 Ford Thunderbird Stereo deck installation issues. I purchased a Pyle Deck and the wiring from the stock stereo has no instructions to crimp which wires to which. The Pyle deck has the instructions on...
Your best would be to buy a harness adapter to connect the new deck through the adapter into the existing OEM wire harness connector. It makes things so much easier and more reliable.
Oct 19, 2013 | Pyle Car Audio & Video
Code for phillips model22dc461/62e, serial number rn461fx2354578
RN461FX2354578...also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
Jul 07, 2013 | Car Audio & Video
How do I change the radio out in my 1994 dodge Sat
Disconnect the negative battery cable from the Dodge battery. The negative cable connects the battery to the frame of the vehicle. Use a Phillips-head screwdriver to loosen the cable'c clamp. Remove the clamp from the negative battery lead post.
Remove the dash trim panel that surrounds the stereo and climate control knobs, using a trim panel removal tool. Start at the bottom of the trim and work the tool around the perimeter until the panel is completely removed.
Remove the screws on either side of the Dodge stereo mounting bracket with a Phillips-head screwdriver.
Pull the stereo unit from the dash mounting bracket. Pull the stereo far enough to reach the wiring connections at the rear of the deck.
5
Disconnect the wire groups from the back of the factory stereo. There are four groups, for the antenna, power supply, speakers, and amplifier. Grab the groups by the plastic wire binders, not the wires themselves.
6
Reconnect the negative battery cable to operate the vehicle or any electrical components. Place the negative cable clamp around the negative lead. Use a Phillips-head screwdriver to tighten the clamp until the clamp cannot be moved around the lead by hand.
May 30, 2013 | Car Audio & Video
Mitsubishi Eclipse Spider Gt-S I cannot figure out how to get the fascia panel and face plate off of the radio to get to the numbers needed to retrieve the radio code. How do I take the panels OFF?
Hi
The stereo in the Eclipse can be removed with nothing more than a Phillips screwdriver
Disconnect the negative battery cable from your Eclipse's battery. Remove the two Phillips screws along the bottom of the radio/climate control trim panel. Lift up the bottom of the trim panel to unlock the lower retaining clips. Work your fingers around the sides of the panel to loosen the other clips and remove the panel. Remove the four Phillips screws holding the stereo in place. Slide the stereo out of the dashboard and disconnect the wiring harness and antenna cable from the back of the device.
Also check this link if it helps:-
http://www.ehow.com/how_5938157_remove-eclipse-car-radio.html
May 04, 2011 | Mitsubishi Car Audio & Video
I have a philips car 400 stereo that is coming up with 'safe' on the screen (the battery went totally flat on the car) the details are as follows GM90493281 4660103...
DELCO codes are only available from the Main Dealer or Radio Decoding Service
They are not available for free from anywhere on the Internet
Sorry
Mar 10, 2011 | Philips Car Audio & Video
Audio switching rapidly between mono & stereo
it's almost like an antenna so if he lives in apartment or anywhere lots of signals are it will do that i would suggest a line clarifier
Aug 22, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Car Audio & Video Logo
201 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
