Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Swisher zero turn mower will start but when pto is engaged mower shut off?????
    Problem Solver:
  • 18 Answers
Safety switch,probably seat.
Posted on Jun 06, 2010
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
Ihavert42.zero turn pto will not work
Check PTO switch
check fuses
check safety switches on the mower.
Mid all good then you will probably need to replace the PTO clutch.
Check switches using a voltmeter
Jul 11, 2015 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
Electric clutch wont engage when when switched on even though I can hear a clicking sound at the clutch.
PTO Clutch will not stay engaged.
There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
It does not give the air gap. It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
  • Cap Screw torque 55 lb-ft (75 N.m).
Fixing Electric Clutches
Apr 11, 2015 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
I have a 60" Lesco
If it were me I would check the PTO switch with it running and use a dvm or test light to see if switch is working or defective , you could just have a bad wire connector at the switch or at PTO clutch ....look for discoloration or spread terminals, good luck
Aug 01, 2011 | Garden
Engine dies when PTO is engaged. I thinking of replacing the PTO!
It sounds like you may have a siezed bearing or something jammed in the PTO mechanism. In any case, you will have to strip the PTO to troubleshoot it. A complete PTO replacement will probably not be called for, just the defective part.
Jun 09, 2011 | Swisher ZeroTurn Mowers
When i engauge the pto the belt and pulley want turn it wants to turn but cant and starts smoking
sounds to me that the blades are hung up, either on the deck or something is caught on the bottom of the deck or top. Carefully inspect all things mentioned, if all checks out good then the PTO is seized. Good Luck Tim
Mar 28, 2011 | Swisher Zt2560 Zero Turn Radius 60" Riding...
My swisher zt blows the fuse every time i engage the blades...can get the engine to run and drive. problem is only when i start the blades. any ideas?
Check the all wiring from the engage blade button back to the electric clutch for worn spots that may be grounding out on the frame.
Sep 17, 2010 | Swisher Zt2560 Zero Turn Radius 60" Riding...
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
152 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
