Question about Akai PDP4273M Television
Tv does not turn off when press power button it changes the channel
  • Akai Master
  • 3,866 Answers
Okay, here is your issue, The little circuit board under that button witch you pressed is malfunctioned "you need to get a new onw". Here is your dilemma tho. Akai does not provide that part you need so you need to take it from another like Akai hence "tv junkyard". Most repair shops have there own TV junkyards where they use good parts from other tv's with like or other problems and sale the part to the prospect called "tansplant" unit.
Now you might do not hold me to this might be able to find it on www.partstore.com. Now here is another method if the IR sensor is still good you can get a universal remote to help you with the "controllign procedure of this tv" until your ready to scrap the tv or ready to put down some cash to fix it.
The part is the tv control module if sold would run about $35 bucks respectively.
Again I am not trying to tell you to junk your TV, I am providing a solution and a wok around here. So please do be considerate of that fact when you press the accept button, Thank You!
Posted on May 31, 2010
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
Need to reprogram my adjusta-magic E-95 remote
Try holding down the tv and power button, if it lights press the channel up button until u see the channel change then press tv. If the channel up button doesn't do anything, try tv power buttons together, this time press the play button until tv turns off. Once tv is off press rewind until it turns on then press stop to lock code in.
If all else fails, replace.
Apr 02, 2014 | Televison & Video
Need code for dynex television, using a nexxtech 1519000A remote.
Programming with Code Search
1. Manually turn on the device (TV or
Cable box) to be controlled.
2. Press and hold the P (Program) button
until the red indicator stays on. Release
the P button.
3. Press and release the desired mode
button (TV or Cable). The red indicator
blinks, then stays lit.
4. Press the Channel Up button repeatedly
(up to 300 times) until the device to be
controlled changes channels. If you
accidentally overshoot the desired code,
press the Channel Down button to
backtrack through the library until the
device changes channels. Pressing
Channel Up changes the direction to
forward again.
5. Press and release the Enter button to set
the code.
If the device does not have a Channel Up
button, use Power instead. If you go all the
way through the code library without
finding the correct code the indicator blinks
a few times then goes off.
Feb 05, 2010 | Dynex 24" Standard-Definition Digital TV
SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1 CHANNEL WORK WHEN YOU CHANGE TO TV CHANNELS 1 - 5 BUT DOES NOT WORK ON DTV CANT CHANGE JUST FROZEN ON CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Dec 26, 2009 | Televison & Video
The Zenith Digital TV Converter DTT900 needs reprogramming
1) While pressing & holding down the TV POWER button, press CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on or off. 2) Release the TV POWER button when your TV is turned on or off. *Each press of the channel button sends a manufacturer code (1-45) to your TV, one after the other. Note: You may have to do this every time you change or remove the battery, as the remote will reset itself to the default code.
Nov 25, 2009 | Televison & Video
I have the radion shack hdtv remote. Cat no
Download the manual and codes from here
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/radio_shack/15135-manual.zip&area=other
Here is how to set the code...
1. Turn TV on
2. Press TV button on remote
3. Hold P button on remote until LED blinks twice
4. Enter the first 5 digit code for Magnavox TV's
5. Press Power button - TV should turn off. If TV doesn't turn off repeat steps 2-5 with the next 5 digit code, until either TV goes off or run out of codes.
6. If out of codes use searching for code method below...
TV codes for Magnavox
10047, 11454, 10054, 10154, 10000, 10250, 10051, 10180, 10060, 10030, 10171, 10092, 10706, 11913, 11904, 11755, 10019, 11365, 11254, 10802, 10386, 10282, 10020, 10187, 10186, 10024, 10179, 10096
Searching for code
1. Turn on TV.
3. Press and hold P button until LED blinks twice
4. Enter code 991 on remote - LED blinks twice
5. Press 1 - Device key blinks twice
6. Press Power button once
7. Press and release CH+ key until TV turns off.
At this point in the manual, the manual is only correct depending on what type of TV you have.
In the manual if you press the Power on button the TV should turn itself back on, the fail to state that not all TV's turn on by the power button, the majority now are triggered to turn on, on channel change, however you can't use channel change here to check it as you'll go to the next code... here is my solution...
8. Turn TV back on either using original TV remote, or buttons on front (most TV's if you change channels they come back out of standby mode, very few now turn on by pressing the power button).
9. Press Power button on remote - TV should turn itself off again.
10. Press P button on remote to lock in that code.
If the device does not turn off press CH- to go back through the codes, press and release P button when TV turns off.
Finding code
If you used the search function you might want to know what code it's using. To do this follow these instructions...
1. Press TV button
2. Press and hold P until LED blinks twice
3. Enter 990 and LED blinks twice
4. Press 1 and count number of times LED blinks this is the first digit of your code (e.g. 1 blink = 1, 2 blinks = 2, etc).
5. Repeat step 4 pressing buttons 2 - 5 for the other digits (e.g. for the second digit press 2 count number of blinks.. etc)
At this point the manual doesn't tell you how to get out of this mode, I presume pressing any other button on the remote other than 1-5 will take you out of this mode, either that or leaving the remote alone for 5 minutes.
Nov 08, 2009 | Radio Shack (15-2147) Remote Control
Rcr311w need help and advice on programming
WHAT BRAND OF TV ARE YOU TRYING TO PROGRAM
Jun 03, 2009 | RCA Universal Remote Control
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Universal remote px-rc1
Hi! This worked for me! I'm Leyz/leheart from the Philippines. I'm typing in CDRKing or CD-R King or CDR King Universal Remote Control PX-RC1 so that these keywords will show up if someone's looking for it too.
Mcneileric is right!
Real TV should be on! On the remote, press and hold the SET and DEVICE TYPE (in my case TV) at the same time. (Note: SET button is not any other button but the one with the word SET on it. You might have been searching on youtube and found that they are pressing other SET buttons but do press the SET button with the SET word). Then press SET again. Press the POWER button then + CHANNEL button then POWER button then +CHANNEL button then POWER button then +CHANNEL. (This process is so the remote could look for the code while you are pressing the +CHANNEL and the POWER is to see if the tv will turn off/respond to the remote). Do this repeatedly until the time that when you press the POWER button, the real TV turns off which means the real TV now responds. You will be shocked so DON'T press the +CHANNEL button anymore as this will instruct the device to look for another code. Instead, press the DEVICE TYPE button (TV for my case) to finish the set up.
NOW YOU CAN USE the REMOTE! Press the POWER button and this will turn on the TV!
Again...
TV onPress and hold SET button (yes, the button with the word SET) and DEVICE type button (TV/VCR,etc) at the same time for about 3 secondsPress SET againPress Power to check if the TV turns off^^If nothing happens, press +CHANNEL to search for codePress Power again to check if TV turns off^^If nothing happens, repeat the step between ^^ and ^^If the TV now turns off after pressing the POWER button, press the DEVICE type button to finish the setup.
Mcneileric, THANK YOU!!!!
Aug 22, 2008 | Radio Shack 15-2142 Remote Control
Silly remote
press and hold "set" then "TV" (or whatever device) then press "set" again. Point the remote at the device and press repeadly the power button until the device turns on. Press "TV" again to complete the programming procedure.
Done.!
Jan 14, 2008 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
