Question about Microsoft Wireless Entertainment 8000 Keyboard
Shift key keeps falling out and won't stay in even with the clip
MS Keyboard 8000
the shift key keeps falling out. is there somewhere I can take it in to get the shift key repaired or a place to send it to?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Try super glue or use tape
Posted on Jul 15, 2010
WHen using the shift key to type the at sign or the esclamation mark etc it does numbers
Is this the only problem with the keyboard not getting uppercase to work ?
While Acer laptops are built to be used on the go, they are not indestructible. An accidental drop or even normal wear and tear over an extended period of time can cause the laptop keys to become dislodged and fall out. Debris can also build up inside the keys and make them stick or stop working. Fixing the keys on your Acer laptop is a quick process that does not require taking the unit to a professional repair shop.
Power off the Acer laptop and flip the unit over. Slide the battery release lever over and lift the battery out of the laptop. Turn the laptop back over and open the lid. Look inside the open area on the keyboard where the key would normally go. Check to see if the plastic retaining clip is still inside the hole. Locate the plastic retaining clip if it fell off the keyboard along with the key. Use a pair of tweezers to set the clip back inside the hole. Line up the holes on the clip with the four raised nodules inside the keyboard hole. Set the key back onto the plastic clip. Push the key down until it clicks into place. Flip the laptop back over if there are keys that are not working properly. Use the Phillips-head screwdriver to remove the three screws on the left side of the case that hold the keyboard in place. Turn the laptop back over so that you can see the LCD screen. Push the thin end of a flat-head screwdriver under the LED indicator strip above the keyboard. Pop the strip upward and pull it off the laptop. Lift the keyboard up towards you until the long ribbon cable running from the bottom of the keyboard to the motherboard comes into view. Unplug the cable from the port on the motherboard and then pull the keyboard and its ribbon cable off the case. Spray out the underside of the keys and the inside of the Acer laptop case with canned air. Reassemble the keyboard, LED indicator strip and battery.
Acer aspire keyboard removal http://www.cyfinity.com/2008/07/acer-aspire-5315-keyboard-removal/
Mar 01, 2013 | Acer Aspire Computers & Internet
My F1-12 dont seem to work when i push them what could be problem
The button is on the top left of the keyboard toggles the meaning of the F-keys from their normal meaning to their special meaning for MS Office apps.
Dec 27, 2010 | EzKey EZ-8000 Smart Office Keyboard
My keys are all shift_ed
Please, if you can, try to remove the keyboard and reseat its cable on the mainboard. The AoA150 has small little clips that are mounted into the top cover that you can push back.
Also try to install USB keyboard and see how that behaves.
From your description, it might either be that one shift key is broken and perma-on, or the keyboard cable wasn't seated properly.
If all fails, try pressing in either shift-key a bit harder for a longer period, and see if the problem gets better or disappears.
May 19, 2010 | Acer Aspire One A150-1006 Notebook
As I am typing on my computer, the cursor bar goes to the beginning and continues my typing from that point. It's really hard to type and then have to go back and fix all the errors, especially since I am...
Either you are pressing the HOME key on the keyboard - it should fall somewhere under your right ring and little fingers - or the HOME key is defective, i.e., stays half-way pressed. Check it if it "feels" different. If it does, Dell keys may be removed by GENTLY lifting them with a fingernail from the bottom and twisting them upwards. Ensure there's no grit, dust, or hair under the key, and verify that the little pod below the key feels right (if it doesn't, the keyboard will have to be replaced. You can find instructions on Dell support site, and a brand new 1525 keyboard should set you back around US$ 15 on eBay). To put the key back in place, position it where it should stay and push it down firmly, first on the top then on the bottom, until it clicks.
If your problem is typing on the HOME key by mistake (or maybe the Ctrl-H key or some other, depending on your word processing software), maybe you can have benefit from one of the many freeware programs known as "keyboard remappers". Just remap the HOME key to something harmless (e.g. shift) when starting the word processing session and remap it back once you're finished.
Feb 28, 2010 | Dell Inspiron 1525 Laptop
Ms 8000 mouse pairing code
You choose your own code. It's a keyboard right? So it has numbers on it...and an Enter key.
1. Press and hold in the small button next to Bluetooth symbol under the keyboard for 5 seconds. The charge indicator lights at the top of the keyboard should alternate flashing red then green.
2. Search for Bluetooth devices on the devices you wish to connect the keyboard to. The Keyboard should be listed there.
3. Enter a code of your choice into the device you are paring the keyboard to and submit it. I used a 4 digit number which worked without a problem.
4. Type the same code and press Enter on the Microsoft Wireless Entertainment Desktop 8000 Keyboard.
The keyboard should now be paired with your device.
Good luck, - GregAndo
Jan 29, 2010 | Microsoft Wireless Entertainment 8000...
Shift key error
dear sir
good day
you can use the caps lock key instade or you can use the ms onscreen key board from accessories then ease of use then chose the ms on screen key board or by the end of the day you can buy a new key board for that :)
thank you
Dec 24, 2009 | Computers & Internet
Hi, I have an Acer 5920 laptop and the right arrow key has come off. I have the key, and the 2 bits of plastic that act as a retaining clip how do the clips fit? I can see that one clips into the key at...
Do not use glue! These keyboard caps just press fit onto the keyboard. Line it up and push straight down. The arrow facing in the right direction should give you the right alignment. If the key does not stay on, you must replace the keyboard as it would be missing the attachment point that would keep it on the base. Without seeing it in person, it is hard to say. I am not sure I understand what you mean by the key is locked to the keyboard?
Dec 14, 2009 | Acer NSK8458AN Keyboard
Gateway m-7301u 15.4 widescreen keyboard problem
The keyboard would need to be replaced because once the plastic tactiles are messed around with they loose there shape plus the metal pieces that the plastic tactiles stay on get bent as well which means the keys won't stay on as well and stay looser then normal, thats why its suggested to get a new keyboard.
Jun 22, 2009 | Gateway M-7301u Notebook
Keyboard key issue in laptop
The metal bar needs to be clipped on to the plastic shift key. Look under the plastic shift key and you can see recess where the metal bar fits. Place the shift key over these recess and push down until it clicks into place.
Jun 12, 2008 | Gateway 2520915 Keyboard
Microsoft Wireless Entertainment 8000 Keyboard Logo
475 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
