Question about Sony Handycam DCR-DVD201E DVD Camcorder
Sony Handycam Disc May Be Scratched Message
I have a Sony Handycam with 6.1 megapixels. Suddenly, the camera is telling me that the disc may be scratched, and I should clean it and try again. Nothing seems to work...not even a brand new disc. Any suggestions?
    Novelist:
    Sniper:
  • 85 Answers
Your camera might have an issue with the lens not reading the disc properly. if you already tried using b/n dvd disc, just make sure there are no smudges on it when you place it in the dvd cam. to futher isolate issue,try playing back discs with previous recordings that you made. if still it doesn't work. reset the camcorder (check manual for reset button location, make sure cam powered on when you press button using any fine-tipped object). if still didn't work.do power reset.remove battery or ac adapter.leave the cam w/o any power source for at least a minute. if your still getting the same problem, it won't hurt to try cleaning the lens using an 8cm dvd disc cleaner (w/c usually comes w/a non-abrasive solution) as the last resort. if everything fails, unit may need service. hope this helps. thanks:)
Posted on Jun 02, 2010
Testimonial: "thank you!"
I get a message on the screen that says, "recording disabled." How do I fix this? I have a Sony Handycam DVD/RW Wide LCD
This message appears when mini dvd disc got some error in recording tracks, if its rewritable mini disc then format it as option is available in camera settings menu and if disc is once writable then use another disc as it can not be formatted.
Caution: Format will erase/ delete all files on dvd disc and refresh the dvd disc.
Jul 25, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
My Sony HandyCam DCR-DVD105 suddenly started shutting itself off after about 20 seconds. I have recharged the battery, and that has not helped the issue. the camera also will not open its disc access, even...
No problems, at last Sony have listened to camera users and heard that the models that use DVD are no good, so Sony along with most others have dropped the DVD models, they simply never were reliable enough.
Grab a Digital 8 tape camera from Sony if you feel you prefer no hasstle in movie making, most already have.
Jul 04, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Disc not supported
does your disc burner support both +/- dvd if not it will only burn either dvd+r or dvd-r look at the disc drive bay for compatibility
Aug 13, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
I have a HANDYCAM SONY DCR-DVD 106, and I keep getting the following message error - "Disc error. Unsupported format - 13:023, with regard to a mini MEMOREX DVD-R.
Disc error. Unsupported format means that ur camera does not support the format of this disc it might not support DVD-R or DVD-RW and supports the DVD+R and +RW try the other format disc and let me know if it resolved , check the manual it is stated on the box or manual which format it supports, if it does not solve ur problem try some other brand instead of MEMOREX try sony,hp,fuji,philips and see actually these sony cameras they are sometimes locked by the manufacturer to only use the original discs for monopoly sony acts like that in every product
pls do rate me if i fixya problem
regards
Zohail
Feb 23, 2009 | Sony Handycam DCR-DVD205 DVD Camcorder
Error C:13:02 - Can't recognize any disks
Not good. It sound as though it will need the disc mechanism unit replaced.
Dec 29, 2008 | Sony Handycam DCR-DVD201E DVD Camcorder
Says disc is dirty or scratched ...it's not
Eject the DVD disc and push Optical Lens inward-outward for 2-3 times carefully. Please dont touch lens surface. Lens should reach completely at both ends.
Hope problem will be solved.
Jun 01, 2008 | Sony Handycam HDR-UX5 DVD Camcorder
Error message - no supported files found on this disc
Hi there, I got the same problem.
All answers received are to finalize the discs or use Sony discs. Both were tried but nothing. I realize the camera was working Ok with Windows 2000 but that happened when I migrated to XP.
HAve you solved the problem as I see your post is very old.
Regards
Jun 27, 2007 | Sony Handycam DCR-DVD101 DVD Camcorder
Problem useing tdk dvd-rw
1. cleaning the laser lens with isopropilic alcohol and q-tip
2. Try the reset button on the bottom of the camera. Tilt your camera and look below the LCD Display Backlight button on the bottom edge of the curved portion of the camera. You will need a paperclip or tip of a ball point pen to push the recessed little button. Place the camera on a level surface and try again. We find that the camera is very sensitive to tilting, as it gets older.
3. Make sure you format format at was FAT not fat32
4. All you need to do is "Quick format" the disk with the CAMERA rather than the memry stick plugged into the computer drive.
5. For sony error c:1301 using mini cd's: there is a program that recovers data from cd's that works with disk that have this error. It called "cdroller" Homepage is : www.cdroller.com
6. just take the memory stick off and re-insert it lot of times.. just keep doing it.
Jun 05, 2007 | Sony Handycam DCR-DVD205 DVD Camcorder
Sony Handycam DCR-DVD201E DVD Camcorder Logo
117 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
