Question about Samsung Televison & Video
How do you change from tv to vcr setting without the remote
  • 579 Answers
SOURCE: Quasar 13" TV/VCR lost remote cannot find menu
You must buy a universal remote and be sure and get one that has a menu button on it.
Posted on Dec 31, 2007
SOURCE: How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Posted on Jan 19, 2008
SOURCE: symphinic SC313E cant set channels
Unplug it overnight. When you plug it back in you should get the set-up menu.
Posted on Jan 09, 2009
SOURCE: lost remote for akai tv/vcr/dvd set
my, need code for programation my combo in remote control rca
Posted on Jan 11, 2009
  • 89 Answers
you might try going to channel 00
If you cannot just dial the number 00, go to channel 2 and then channel down.
Does not always work, but without the model number of the TV it is hard to advise further
Posted on Mar 13, 2009
How do i manually program my channels on older tv without a remote
Nothing you can do without the original remote. One cannot get into the setup pages. Replacement remotes usually don't work on this point either. They are missing this special setup button. In order to watch DVD, VCR, connect them with a SCART cable. When you switch on the player, the TV will detect this and go automaticaly to this input. If connected with RCA plugs, you can choose the input with the program Up/Dwn buttons on the TV set itself, going "lower" than channel 1.
Jan 04, 2014 | Philips Magnavox 20MT133S 20" TV
Need to change input, no remote
There is no way to change the input to this set without its remote control.
Apr 12, 2012 | RCA Televison & Video
Magnavox 20MC4304 20" TV/DVD/VCR Combo Remote:
A universal remote should solve your problem. You should be able to find one on ebay. You may even be able to find one for your particular TV on ebay as well.
Dec 03, 2017 | Magnavox NE206UD TV/VCR/DVD Combo Remote...
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Mar 12, 2009 | Televison & Video
Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Dec 02, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
WHITE-WESTINGHOUSE TV/VCR COMBO NEED CODE
The code for the TV is 0623 but to use the TV/VCR button to change mode from line to TV the code is one of the following 0179, 0451, 0463, 0624 or 0278. The 0623 only activates the menu but doesn´t let you change Air/Cable mode without first changing the Line/TV mode by pressing the TV/VCR or Line input button on your universalk remote with one of the other codes.
Oct 28, 2007 | Zenith ZN110 Remote Control
Feb 18, 2007 | Samsung CXJ1964 19 in. TV/VCR Combo
Televison & Video Logo
29 people viewed this question
Jerry Greenberg
Jerry Greenberg
