Question about Car Audio & Video
2005 freightliner columbia. replacing factory radio. All wiring is grey :-( Anyone have a diagram showing what pin is what?
Holding the harness and looking at it as it would plug into the back of the stereo you have 8 wires in the top half of the harness and 4 in Tue bottom. Working left to right on the top half first is the rear left speaker, front left speaker, front right speaker and rear right speaker. The positive speaker wires are on top the negatives are on bottom.
For the lower half of the harness you have 1 wire in the top row and 3 in the bottom. The one on top is the switched wire to turn the stereo on and off with the ignition. The bottom row from left to right is ground, and 2 constant power wires for stereo memory you can use left right or both to connect to your stereo's memory lead. I hope this helps I was looking to and had to map the wires using some educated guessing and a multi-meter.
Posted on Apr 20, 2011
  • lilhazerd Apr 20, 2011
    I apologize I had a couple wires backwards the 1 on top is the memory lead and the 2 to the right of the ground are both switch. Sorry for any confusion.
  • Jay Rock
    Jay Rock Aug 21, 2017
    Wow!!!! Thanks alot... two weeks without a radio until i read this post. Again thanks lilhazerd
Abs light is on all the time sometimes I get a code
Abs sensor will need replacing, cleaning them won't help, you need a code reader to see which one needs replacing then you need the code reader to delete the fault code
Feb 11, 2015 | Freightliner Columbia & Century Class 120...
Where can I get a radio wiring diagram for a 2005 Lexus GS300? I'm trying to replace the factory stereo that no longer works with an aftermarket Kenwood stereo.
I would just google image search it there will be a lot of pics that nothing todo with it but there will be at least one of what you need
Nov 07, 2014 | OEM 2005 Lexus GS300 Radio / CD Player...
Replacing expansion valve
following the line connected from the front mounted condenser to the compressor pump at front of engine , it's mounted in that line ,(small) use extreeme caution as theres a lot of pressure there on that line , fyi if your expansion valve is plugged your compressor is bad as well!!
Aug 31, 2014 | Freightliner Columbia & Century Class 120...
Want to install an apline stereo into a freightliner columbia
Just follow the Aftermarket Wiring Diagram and you will be fine
Apr 12, 2013 | Alpine Case Cda-7873 Cda-7875 Cda-7876...
06 freightliner columbia sm codes on 12 speed smart shift
2005 freightliner columbia smart shirt does not take a gear and code shoes up sm.
Apr 24, 2012 | 2007 Ford F-650
Trying to install after market cd player in freightliner. need wiring diagram or wiring harness adapter. model # 12244075
i have got the same problem. took out factory stereo out of my 2005 m2 106. only to find all wires to be gray with no markings. it has a 12 pin connector. can anyone tell me the how to hook-up new regular 10 wire cd player
Aug 24, 2010 | Car Audio & Video
Steering wheel removal instructions for 2005 freightliner columbia
you will need a specel tool so you will not cut your horn wire that comes up through the shaft,I made mine and the bolts that go in the steering wheel to pull it off are metric,if you need a pitchure of it I will email it to you,wilsodfarm@yahoo.com
Jun 30, 2009 | RTO Ho Herpa Freightliner Truck Tractor
Car Audio & Video Logo
2,266 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
