Question about Goodman CLQ60AR61 Air Conditioner
My unit is 3 years old. We have recently heard
My unit is 3 years old. We have recently heard water leaking in the crawl space where our main vent and filter are. The unit is located directly above this. We were told to pour bleach down the pvc tube that it was probably clogged up with algae. We have done this 3 times in the past 2 days. The unit isnt cold when this is happening. We have to turn it off and hope it works for a little while. Do you have another solution
  • 146 Answers
Sounds like the evap coil is freezing. it is frozen if you have low air flow. check the lines and see if your suction line is freezing. also check your filter. if you think your drain line is clogged cut the line and blow out with an air compressor or nitrogen. all you should need to fix the line would be a 3/4 in coupling or a union. hope this helps
Posted on May 31, 2010
I recently had a water leak in the crawl space of my house. It is being dried out with several fans,and a dragon, blowing hot air under the hose. This will continue to go on for another week. Now I&#
Very likely.
Here's why.
Because of the real danger of overheating and fire, dryers are "loaded" with overheat switches which will shut thr dryer off if they get hot.
One reason is that lint catches fire so easily.
Here's hoping you problem will resolve soon!
Be blessed
Jan 27, 2013 | Kenmore Dryers
Help! We bought out home 3 years ago and have a Nortiz tankless water heater. Recently we heard a dripping sound coming from the water heater and found that the bottom of the unit is leaking. We had a...
you will need to explain more of where the leak is on the bottom. You have two plastic valves on the bottom and if the clips are not on exactly it will leak and if the person who replaced valves did not use vasoline when they put it back together the could have cut the gasket ring on the inside putting in back together and again it will leak. You have to determine where the leak is coming from to begin with using a flash light to get the exact location. .
Oct 05, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
We have a one year old home and started to notice
do you have floor or ceiling vents, and does your house have concrete flooring or do you have a crawl space under depending on the answer because if you have a unit that is all outside then the duct may not be sealed
Jan 08, 2010 | Ruud UBHC Air Conditioner
Our PowerStar PS19T tankless water heater
The PowerStar AE115 unit replaces the PS19T model which has been discontinued. Now's the time to upgrade...
Nov 08, 2009 | Bosch PowerStar AE115 Tankless Water...
Humidity build up in crawl space
yes we had that problem a couple of times a couple of years ago and installing another unit cut it less than half.
Jun 22, 2009 | Lomanco PCVI POWER CRAWL SPACE VENT Fan
I can not find the furnace in our home. Is it in the attic??? or crawl space??? i have a newer home in Phoenix
it could be an air handler in the attic, do you have gas or ele. some are built into the water heater if it is gas, do you have base boards running around the bottom of your floor or air vents with am ac condesor outside if this is the case it could be either the crawl space or attic
Jun 06, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Replacing an old dryer.
they make a dryer vent kit that blows down into a basket that has water
May 20, 2009 | Dryers
My Central heating system as no vent
You are talking about a gas fired system I assume. So no, it's not a big deal. Code now states that you need to vent the gas furnace from the attic or a crawl space and not from the living space. They change this code back and forth all the time. It's nothing to worry about if you do not plan to sell the home.
Apr 01, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Moisture sensor not working
Once I discovered that the problem was not the dryer, I went into my crawl space and discovered the plastic duct was clogged with lint. Apparently the duct was not changed since the house was built over five years ago! The 4" duct was also duct taped to a 3" connector. Additionally the line ran into the crawl space at a 90 degree angle in a space that was only 2" wide! My husband adjusted the way the line ran into the crawl space and replaced it with a rigid aluminum duct. The auto sense works on my dryer and it takes only 30 min. to dry a load of laundry instead of 1-1/2 hours!
Dec 04, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Carrier Air Conditioner Infinity System - Air Handler Sweating & Duct Work Condensation
Either its not drainning mositure properly or low air flow across the "A" coils- caused by dirty filter .
Sep 12, 2008 | Heating & Cooling
Goodman CLQ60AR61 Air Conditioner Logo
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
