Handsets keep showing out of range, I've had it hooked up to a magicjack for about a week and suddenly the handsets will not sign on
2 Suggested Answers
SOURCE: fax magicjack
  1. Operating Systems
    • As of 2010, the Magic Jack works well with Windows XP and Vista machines. Windows 7 has reported problems listed on their Microsoft Answers forum.
    Do Not Support
    • According to the Magic Jack company website they "...do not officially support using faxing with Magic Jack."
    Testing the Fax
    • Test your fax machine with Magic Jack by turning off the error correction on the machine and using the slowest speed available. If successful at that speed, increase the speed and check if it continues to work.
Read more: Does Magic Jack Support Faxing? ' eHow.com http://www.ehow.com/facts_7148239_magic-jack-support-faxing_.html#ixzz1tntAK093
Posted on May 03, 2012
Why won't my magic jack work plugged into the wall outlet?
Magicjack uses the internet. It has to be hooked up to a computer using the internet. Its just skype for regular phones. Skype is free. magicjack cost 20 bucks. its a scam
Oct 27, 2014 | Cell Phones
When i make or receive a call with my magicjack they can;t hear me
When using the MagicJack are you using a phone handset that you know has a working microphone in the handset.
Test the phone in a normal phone plug.
If the phone works the you need to talk with support at MAgicJAck as your device might be faulty
Try http://www.magicjack.com/customercare.html
If they cannot help take up the 30 day free return option and swap it for a new device.
Jun 30, 2014 | Android Apps
Magicjack and a usb handset device from tigerjet are suddenly in my computer's speaker mixers. now I get no sound through my computers speaker, however that sound is coming through my telephone speaker...
I am assuming you are on a windows machine.
Right click on the speaker icon (volume control icon) normally located near the time lower right hand corner of the task bar. When you right click a sub-menu should pop up.
Select "Playback devices" and then select the "Speakers" option you wish the sound to play back on.
Hope this helps.
Sep 07, 2013 | Computers & Internet
MagicJack used to work fine. But now the other person can't hear me. Why?
You cannot use the magicjack in this way. The magicjack is used to enable the telephone to be used instead of the computer.
Plug in the magic jack device when the internet connection is working and it should download the software to make it work.
Jun 04, 2012 | magicjack.com
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
Jun 16, 2011 | Uniden Cordless Phone
My 8310 shuts off at 80% battery power and has been for about two weeks. Also to turn it back on it must be hooked into a wall outlet. I had a problem with an incompatible battery sign showing up but the...
I would really recommend replacing the battery in the handset. Keep in mind retail stores usually are much more expensive than online ordering...
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_156682b88afabb53
Dec 12, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Every phone has handset
All four phones showed "Out of Range" I unpluged the main phone - the one with the telephone hook up. I left it unpluged for a few minutes, plugged it in and IT WORKED> Thanks for your interest in helping me.
JJS
Nov 19, 2009 | Uniden 2.4 GHz Cordless Phone System
No ring on incoming calls
I found this in statement in a review of Magicjack on Amazon, hope it helps.
The one problem I did encounter was at the beginning when I found that one of my phones wouldn't ring when someone called me. By googling the problem, I found out that this problem is due to the ringer equivalency number (REN) of the phone you are using (google "phone REN" to find out what it is). Most phones have their REN listed at the bottom of the base unit. From my experience, I believe Magicjack will only work for phones that have REN of up to 1.0B (add up all phones in your system to get your total REN. Mine had a corded base with 0.6B REN with 2 more cordless handsets. I figured that made my phone system total to 1.8B REN). Magicjack did ring on a phone that had 0.98B REN. To fix the problem, I bought a multi-handset GE DECT 6.0 (model 28223 Series) which basically has REN 0.0B. Magicjack had no problems ringing with this phone. My phone system was over 3 years old anyway so I didn't mind replacing it.
Jun 30, 2009 | Uniden Lands Phones
Phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
Oct 19, 2008 | Vtech Cordless 6041 Phone
Computers & Internet Logo
265 people viewed this question
David Payne
David Payne
