Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
My Whirlpool upright frost free freezer will not drain water into drip pan. it keeps draining into freezer.
    President:
  • 1,561 Answers
The solution is to first completely empty the freezer (sorry), unplug it and remove the cover in the back of the freezer case. This is usually a full metal sheet with screws securing it to the case. If you find it in several pieces, it is probably the bottom section you need to remove.
Once you've uncovered the inner workings of your freezer, you need to locate the rather obvious defrost elements - these will usually be exposed cooper rods or tubes that heat up during each defrost cycle. Find the defrost element that is closest to the freezer's drainline, and wrap one end of the cooper wire around the defrost rod about 5 or 6 times - then run it down the inside of the rear of the freezer case, and into the drain itself, about 6 or 8 inches or more if possible.
What you have just done is to assure that each time your freezer defrost comes on, the drain water will always have a clear and unfrozen path out. Replace the cover in the back of the freezer case, and put your food back in. Plug the freezer back in. this should fix the problem.
Take care.
Posted on May 31, 2010
  • charlotte119 May 31, 2010
    Thank you so much for your help we will try this!
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the freezer compartment. Then the water builds up at the bottom, inside of the freezer. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. Click on the link to read more:
http://www.ehow.com/how_2171360_pooling-frostfree-refrigerator-drain-holes.html
    President:
  • 949 Answers
This is due to the defrost drain being clogged. If you unload the bottom of the freezer and look behind the shelves, below the back panel is a trough that is sloped toward the center. In the center is a hole that the water is suppose to drain into. Yours will be full of ice. If you use hot water and a turkey baster to force the hot water down the drain it will eventually clear, it may take a while.
This may need to be done every couple of years.
Let me know if you have questions
    Thank you for your answer. My husband is tired of messing with it tonight.(;-) He says thanks and will try this out. This is a great site!
Does the upright freezer model# 29701000D have a drip pan?
if it is a manual defrost freezer it will not have a drain pan. if it is a frost free freezer then it will have a drain pan
Jul 27, 2014 | Freezers
How do I remove the drain pan to clean it. My freezer is frost free frigidaire upright. The defrost timer went out and some of the food defrosted and drained into the pan and on the floor. There is some...
On older freezers/refrigerators the drip pan could easily be removed. On newer models its now part of the base frame and their is no way to remove it. Dam shame if ya ask me since it was recommended noraml to remove and clean drain pan every couple months, but hey ain't modern technology great hehehehe
Gene
Aug 01, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My frost free freezer has had a small puddle of water under the front right corner several times now. I unplugged it and let it defrost completely thinking that would stop the problem but it hasn't. Can...
There is a chance the water is coming from the drip tray and or the drain hose to the tray.
when the unit goes into a defrost cycle it is leaking from one of those places check and make sure the hose is in the drip pan correctly and that the pan is also mounted properly and level.
If there is is a lot of water in the pan you may need to check the door seals on you unit and make sure they are sealing properly.
If there is an air leak then the unit could have excessive ice build up and also be defrosting more than usual amounts of water.
Jan 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ice keeps forming on the bottom of the freezer - like a leak on the back side flows into the bottom toward the door.
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
Oct 06, 2010 | Amana 15.0 cu. ft. / 425 liter Upright...
Water leaks onto floor once a week or so from under freezer
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Nov 21, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
Frigidare Model No. FFU1464DW2 is leaking water on ground floor, can you tell me where to find the drain pan and what is causing this? Many thanks.
Most likely it is leaking because the drain in the back of the freezer is clogged. The most likely source of excessive water drainage is a bad door seal which causes frost to build up.
Nov 19, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
Ge feezer model fuf14dtarwh upright. i am getting water on the bottom of the freezer which is frozen. what is causing the problem? of course the warranty is over by 9 months and the ge people won't help.
Sep 23, 2009 | GE 13.7 cu. ft. / 388 liter Upright...
Freezer forming Ice on the bottom not draining water
pour some hot water in the drain if this does not work use compressed air
Aug 23, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Puddle
all frost free freezers have to defrost the coils. there is a drain pan or cup in the bottom .. if it overflows or it can't drain out you will get puddles check the drain hose and drain cup or pan.. also check to see if you have ice inside the bottom of you freezer that would be a plugged or freezing drain hose..call for services if only 4 months old...
Apr 20, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
271 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
