Question about Fisher and Paykel WA37T26G Top Load Washer
Washer won't spin, keeps giving unbalanced alert
  • 159 Answers
You probably have a faulty Out of Balance Switch.This is a little micro switch inside the control box underneath the main computer module,right hand side.You will need to remove the modle to get to it.
Posted on Jun 01, 2010
My Samsung washer model wa456 will not spin all the way out with even just a few clothes in it and shakes really had, what do I do?
Washers have a switch which disengages the motor if the load is unbalanced. An unbalanced load will cause the drum to spin irradically and bangs against its bumpers Either you are not loading it correctly or one or more of the flexible supports that keep the drum centered, are broken or disconnected.
Feb 15, 2017 | Samsung Washing Machines
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
When the washer displays uL when spinning?
'Unbalanced Load' occurs when the machine detects that one side of the tub is heavier than the other.
This most often happens when heavy and/or large items become pushed to one side of the tub during the wash and become much heavier when the spin cycle engages.
This is more often seen in 'tub' style machines rather than front loaders.
Usually the machine has a safety system which shuts down the spin cycle and 'buzzes' to alert you to reach in and move things around in order to rebalance the load.
Jun 04, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio keeps giving Unbalanced Load message and has become very loud lately
Check your pump . make shore water is pumping out of drain hose fast/ if not clean objects in pump or pump impeller is broken? replace pump.
Feb 03, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer is shaking while spining
Just from what you stated .If your cloaths are unbalanced it will wobble while in spin cycle,if its not unbalanced, Probily a broken spring,these units use 3-4 springs ,on the wash drum ,to keep them stable while in the spin cycle.
Feb 10, 2012 | Bosch Nexxt 500 WFMC3301 Front Load Washer
How do I get my machine to just spin a load? It became unbalanced and I adjusted it and now just want to spin the water out?
Turn power on. Without selecting a cycle, push the spin speed button to select the spin speed you desire. (if you had an unbalanced load, I'd suggest a low spin speed. You can repeat after with the next higher speed if desired) Push start.
This will give about a 12 to 14 minute pump and spin only cycle.
Mar 21, 2011 | LG WM-2277HW Front Load Washer
My machine will not run the spin cycles, and makes a very loud noise during the spin cycles, sounds like a bad motor or bearing?
I'm not a repair professional. I am just a 78 year man who has done his own washer repair for about 50 years. You might have a bad lid switch that keeps the washer from spinning. You might have an unbalanced load in the machine which makes the noise. The unbalanced load might also be the cause of not spinning.
Nov 23, 2009 | Hotpoint VBXR1090B Top Load Washer
During spin cycle it becomes unbalanced and it beeps and stops
It sounds like the sensing arm of the out of balance switch assembly is wrongly set. Get the guy back to do the job properly at no charge!
Oct 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Uc code error
uc code means unbalanced condition. My research shows this as being an unbalanced load or a faulty control board.
Make sure your load is balanced, otherwise you may have to replace the control board.
Jun 04, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Fisher and Paykel WA37T26G Top Load Washer Logo
137 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
