Question about E-Machines eMachines Desktop PC
Blank screen after windows intro screen
Hello, I had an old hard drive and hooked it up to my emachine desk top in the open second spot to do so. It didn't work, so I took out my already working hard drive and put the old drive in its place- didn't work. I put the working one back in and now my computer starts and shows the start up windows screen and then goes to a blank screen forever. I have the back up disc back hope I won't have to lose all my music files. Thanks
All u do is run it in safe mode for a while maybe delete some stuff it might be to much for comp
Posted on Apr 11, 2008
Como hago mi myscape
Posted on Apr 08, 2008
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
How do you restore a emachines el1200 desk top to factory settings
[1]
reinstalling the operating system If you can run Windows...1 Click (Start), All Programs, eMachines, then click eMachines Recovery Management. eMachines Recovery Management opens. 2 Click the Restore tab, then click Restore system to factory default. The Confirm Restoration dialog box opens. 3 Follow the on-screen instructions to finish.
[2]
If you cannot run Windows...1 Restart your computer, then press the ALT+F10 keys during startup. 2 Follow the on-screen instructions to finish. IMPORTANT • • If your hard drive has failed and you can't restore the software from the hard drive or recovery discs, contact eMachines Customer Care for help. After you restore your computer, it will appear with the same files and programs it had when it shipped from the factory. You still need to download Windows updates and antivirus updates to bring your computer's software up to date.
Aug 27, 2011 | E-Machines eMachines Desktop PC
I have an emachine T5062 desktop. A friend of mine took an old hard drive out of another machine and added it to this machine. Now the desk top won't boot to windows - it keeps rebooting and sounds like...
You need to set the second hard drive up as the "SLAVE". There is a small jumper on the end of the hard drive where the power cable and data cable plug in. There should be a diagram showing where the jumper is placed to make it the SLAVE.
As far as figuring out which is which (MASTER .vs SLAVE), the MASTER is the last drive on the cable.
I hope this makes sense...
Good Luck.
Jan 27, 2011 | E-Machines eMachines Desktop PC
I could not get my sylvania netbook to connect to my wifi so i download the update from their website to a SD card then opened on the netbook and it deleted everything on the netbook. how can i restore it...
I do not know why your icons disappeared by running the Download, but your programs are still in the on board ROM memory and what you are missing are your desk top icons. I have tried to duplicate your download problem but so far have not been able. I know that using a SD card will not download a usuable file so I used a thumb drive.
Any way please read the following solution that I wrote to another poster.
If you have deleted the icons for those programs on your desk top, then they may be in your Recycle trash bin. double click on Recycle Bin look for the icon for recorder, right click on recorder and select restore. You really cannot delete the programs from your machine as they are retained in a ROM chip , hard coded into the chip and are loaded each time you cut your machine on. The only thing you can do is delete the icons on the desktop, which are sent to the recycle bin.
To retore the machine to factory settings, there is a small hole just about an inch down from the data plate on the back. Using a pencil point or a straightened paper clip, insert the bject into the hole and hold for about 5 seconds. Your deleted icons are not replaced.
A second method to restore your icon is to click on my computer right click on the recorder, select copy, dismiss my computer, find a blank spot on your desktop and right click on that spot, select paste, and a dos type icon appears as your recorder button. When you cut the machine of and back on the Dos type icon is replaced with a CE type icon
To restore all icons:
You can: If you can click on start, click on run, type desk top into the open space and ok it. your icons should be shown. you will have to copy and paste each one back to your desk top, or select edit and then select select all, then click on file, select send to, and select desk top as short cut. Reply
Dec 12, 2010 | Sylvania G-Netbook
I have this problem too but I hook it up to my desk top via usb and I can see all my files I put it back in my lap top not it says bootmgr missing and it still says replace hard disk. will I still get the...
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully. 8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
Oct 11, 2010 | HP Compaq Presario F756NR Notebook
EMachine e627 screen blank
I am assuming you have plugged the screen into a known working power source. You have pressed the 'on' button to turn the screen on and you have hooked up the screen to the back of the computer. What I need to know is if when you power up the computer if you see any text at all from the post AND if you see any lights on the front of the screen itself. (most all screens have lights on the front of them to tell you they are turned on, and most of the time the light is green). If the screen is on but is getting an orange or amber light that means something. Also if you see text or something on the screen initially but not in windows then it could be a resolution or driver issue.
Jul 07, 2010 | Acer Computers & Internet
Pc screen for emachine is upside down
Hi Johnson,
please follow these steps and let me know if you still not able to get your screen back to normal.
For window xp, go to a blank spot on your desktop
Right click
go to "Properties"
click on "settings"
click on "Advanced"
click on "rotation"
go from there
For Window 2000, go to a blank spot on your desktop.
Right click
go to "Properties"
click on "settings"
click on "Advanced"
go to "graphics driver"
click on "graphics properties"
click on "rotation"
go from there
kam
Dec 08, 2008 | E-Machines eMachines Desktop PC
Black screen
Some USB devices seem to cause this problem. I've had it myself. USB devices when hooked up cause the computer to freeze as it hard for USB drivers to be loaded outside of windows. Try updating you windows thru windows update though even updated I still run into the problem sometimes. If updating dosen't work you need to keep the drive unhooked while booting then hook up in windows.
Dec 11, 2007 | Dell Dimension 8400 PC Desktop
E-Machines eMachines Desktop PC Logo
50 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
