Soundon WHT 510 Wireless Speakers Not All Connected
Hello...my coworker has the Soundon WHT 510 Wireless Speaker System.
4 speakers come with the system. However she was only able to connect 2 of the speakers through trial and error as unfortunately the manual was misplaced. We cannot log onto the soundonusa.com site as they seem to have shutdown which we had hoped to do to find an online manual.
If anyone can revert to me regarding these speakers on how to connect all 4 speakers correctly I would greatly appreciate it.
  • Alexander Knowles May 31, 2010
    i was hoping for a more detailed suggestion actually. All the speakers are wireless, i.e., they do not connect directly to any DVD or PC. Surely someone must have these speakers or can direct to an online manual about them.
  • 32 Answers
Try to swap the speaker that are hookt up with the ones that are not ,or thay are out of range from the recever
Posted on May 31, 2010
  • white_nathon Jun 01, 2010
    what i ment was try to hook them up at a friends,to see if they work there. I know that they are wireless, did they come with a cd? try this copy this link www.avsforum.com/avs-vb/showthread.php?t=905326 secent link on the page.
Door speaker wiring colors
1995 Dodge Ram 2500
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Feb 16, 2017 | 1995 Dodge Ram 2500
My panasonic says f61 when i switch it on wat do i do
An F61 error occurs on a Panasonic home theater system when the speaker cable wire connections are wrong. This situation is likely to happen if you just purchased your unit or moved the system and try to reconnect the speakers again. Polarity is key in a successful setup. The positive and negative ends of the cable wires must match the input of the main unit. Retrace your speaker wire connections to clear error F61.
Step 1 Attach the speaker labels to the speaker wires for easier identification, if they're not already labeled. At minimum, labels for front left (L), front right (R) and center speakers should be included in the packaging contents that came with your system.
Step 2 Verify that the white ends of each speaker cable are connected to the corresponding "+" positive inputs for each speaker.
Step 3 Verify that the blue ends of each speaker cable are connected to the corresponding "-" negative inputs for each speaker.
Step 4 Push the plastic ends of the speaker wires on each speaker to verify that each is locked into place.
Step 5 Connect the remaining end of the "Front (L)" speaker wire to the white terminal/connector on the main unit.
Step 6 Connect the remaining end of the "Front (R)" speaker wire to the red terminal/connector on the main unit.
Step 7 Connect the remaining end of the "Center" speaker wire to the green terminal/connector on the main unit.
Step 8 Connect the remaining end of the "Subwoofer" wire to the purple terminal/connector on the main unit.
Step 9 Connect the remaining ends of the "Surround (R)" and "Surround (L)" speakers to the wireless system.
Sep 11, 2016 | Panasonic Audio Players & Recorders
1992 dodge dynasty radio diagram
Assuming the radio connects to the RS amplifier, the harness is as follows:
From fuse 13: PNK or BLK -> PNK/LT BLU -> PNK or BLK -> PNK/LT BLU -> radio (!)
From fuse 20: RED/WHT -> radio
From fuse 10: VIO -> amp
From radio: ORG and BLK/YEL to interior lights
From radio to amp: DK BLU/RED, BRN/RED, DK BLU/ORG, BRN/ LT BLU, VIO, DK GRN or DK GRN/WHT, DK BLU/WHT, BRN/YEL
From radio to pwr ant: DK RED/GRN
From RS amp to:
R. door: LT BLU/VIO and LT BLU/DK GRN
R. front: ORG/BLK and ORG/RED
R. rear: TAN/BLK, TAN/RED, TAN/DK GRN, and TAN/VIO
L. rear: WHT/DK GRN, WHT/VIO, WHT/BLK, WHT/RED
L. front: YEL/BLK and YEL/RED
L. door: LT GRN/DK GRN and LT GRN/VIO
Mar 17, 2017 | 1992 Dodge Dynasty
I have the Sony HDX265 5.1 home theatre system, I moved on 7/1/2010 & lost a few stuff (including the 4 surround speakers). How can I buy just the speakers? Please help!
all you need to do is by a set of new speakers same size and have then wire up to the player they will work just as well almost all speaker oulets sell speaker packs of 2 or 4 or 5
Dec 29, 2010 | Sony BRAVIA DAV-HDX267W Theater System...
I have a Samsung HT-510 Center Speaker that has no sound. I was going to take it apart to see if there may be something loose inside. I took the 12 screws out of the back, but still cannot seem to get...
It takes a bit of force, but be careful. the back terminals are connected to the speakers by rather short lengths of wire. The other probable causes are that:
The amplifier's center channel has failed
The wire is shorted or frayed, or defected in some other way.
The speakers are broken. If this is the case, any speaker of 170 watts or lower will work, but it MUST be of 3 ohms impedance.
Jun 14, 2010 | Samsung HTZ-510 Theater System
No sound coming from my new speakers. the sound card is installed and when I check the soundon the computer it says it is working properly. I dont know what to do. sound volume is alll the way up
Check Socket Connections. Speaker connector should be plugged to Green Colored Socket.. Check for "Mute" and that should be in turned off. if problem continues, check the speaker cable and speaker circuit section.
Jun 09, 2010 | Acer Aspire X1300 (PV.SCC0X.002) PC...
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Wire diagram
guynoir..with alpine your other set of speakers would most likely run through an amp ,which may connect up by the rca leads or a din plug , this is where your fader comes in to play.i was an agent for alpine
Feb 07, 2008 | Car Audio & Video
Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Mar 18, 2007 | Bose Lifestyle SA-3 2-Channel Amplifier
My panasonic wireless surround sound won't work out of the Rear speakers
I have finally got my rear speakers to work. wireless internet or cordless phones will stop the speakers from working, i switched off my wireless internet and hey presto speakers work fine, i just cant have both at the same time.
Jan 20, 2007 | Panasonic DMR-E50 DVD Recorder
260 people viewed this question
 Grubhead
Grubhead
