Question about HP Office Equipment & Supplies
Hp designjet 500ps having problem with a system error 86:01 severe error 0x8010003. cannot turn the printer off from the switch. Please help. Thanks Gil
System error 81:01
Posted on Jan 07, 2009
Hp 500ps severe error code Ox40d0003-
If any of the troubleshooting steps listed below solve the problem, attempt to verify printer functionality (instructions listed below). If functionality is verified, no additional parts should be replaced.
    NOTE: Always verify the printer's current Firmware release and upgrade as needed.
    1. Turn the printer off, then on to verify error. If no error attempt to verify functionality.
    2. If the error appears or problems persist, continue with the remaining steps.
    3. Turn the printer off, and disconnect the power cable.
    4. Remove the right end cover.
    5. Check both Ink Supply Station connections on the Interconnect PCA. If the unit shows the error on boot up verify that the connector with the blue wires is seated correctly (Connector P4). If the error appears when a print job is sent to it verify that the connector with the red, black and green wires is seated correctly (Connector P2).
    6. Reconnect the power cable and turn the printer on.
    7. If no error appears, attempt to verify functionality.
    8. If the problem persists, continue with the remaining steps.
    9. Replace the Ink Supply Station (refer to pg. 8-48 of the HP Designjet 500 and 800 Series Service Manual).
    10. Following replacement, attempt to verify functionality.
    11. If the error reappears, replace the Electronics module (refer to pg. 8-24 of the HP Designjet 500 and 800 Series Service Manual).
Jan 02, 2017 | HP DesignJet 500ps (42 in.) InkJet Printer
I need solution on this Problem, HP DesignJet 500 Plus Error: Severe Error: 0x8010003, Thanks Biar R
Turn off the power ->open the cover and manually move the Cartridge carrier to the middle of slider bar that's all , it will fix your problem. Most of the time it is due to friction in the slider rod so lubricate the slider rod if necessary. If the carriage is stuck at the right hand side of the printer and cannot be moved out to the center of the print platen it is because the service station cannot uncap the print heads. in this case replace the service station/aerosol fan assembly.
Feb 13, 2013 | HP DESIGNJET 500 InkJet Plotter Printer
When printing a PDF File I get this error Task:
Download the newer verson of firmwere your problem will be resolved....
Jul 18, 2011 | HP DesignJet 500ps (42 in.) InkJet Printer
Hp designjet 800 ps plus system error severe errora: 0x8010003 task: tmech file: sequence.c line: 636
Notate the error and put it in a search. Since it appears to be a server error, remove then reinstall the driver software.
Jul 09, 2011 | HP DesignJet 500 InkJet Printer
Designjet 500 comes up with error code: severe error 0x8010003 and the belt looks slack. What can i do?
Called a service company who are going to fix it on a fixed cost visit to our premesis.
Oct 27, 2009 | HP DesignJet 500ps InkJet Printer
"System Error" has occurred when the power is on.
same problem....what is the fix? - asap PLZ. In advance, thx
Dec 15, 2008 | HP DesignJet 5000 Printer
2,289 people viewed this question
Ben Johnson
