Question about Coleman Powermate Powermate 5000W Generator
Won't start has not been started in five years, has new gas,new oil and new spark plug
  • 905 Answers
Assuming the engine spins...
1) The carb could have had fuel still in it when it was put into storage. The fuel evaporated out, leaving behind residue that has likely plugged up the passages / jets. Pull the carb, disassemble (get the service manual from powermate.com), clean everything you can (this is likely an EPA carb, some areas sealed), then reassemble with new gaskets, orings, float seat, etc.
2) Rings / valve may be sticking or not making good enough of a seal for proper compression. To check this, remove the plug, screw in a compression guage, spin engine a few times. Note the reading on the compression guage. If it is less than specified in manual, then start looking at rings and valves. If compression meets specs, goto #3.
3) While you have the plug out of the engine, hold the threads to the head. Spin engine. You should see a healthy blue spark. If not, then start troubleshooting the magneto / ignition module.
Posted on Jun 11, 2010
    Scholar:
  • 142 Answers
The carburator may be empty. Open it and fill it with fuel before starting.
Other way is to get a starter spray, open the input collector or where it is possible and spray while starting.
Posted on Jun 04, 2010
2 Suggested Answers
SOURCE: Powermate 4000 with Briggs &
Next step is to check that the magnet attached to the fly wheel is working properly. When you crank the generator over, put a multimeter on the leads to the magnet and look for a spike in the voltage. Be sure to get the polarity correct or you will damage your multimeter. If there isn't a spike in the voltage, then either the magnet is bad or the fly wheel is damaged. In either case parts will have to be ordered and replaced. If there is a spike in voltage, then it is time to check the fuel intake. Open up and take out the air filter. Inspect the air filter to make sure it is clean and doesn't have fuel or oil in it. If the air filter is we with either things, then this will prevent air from reaching the engine. This alone will cause it not to start. If the filter is clean, then leave it off and open up the throttle. This will give you direct access to the engine through the fuel intake. Put some fuel into a spray bottle, and when you crank over the engine spray some fuel into the hole where the air filter was. If the engine starts/sputters then you have a problem with your carburetor. If the engine doesn't start then you have a deeper issue that may require a trained mechanic to fix. Lets say that if the engine does start/sputter, then we need to take the carburetor off. Our goal is to clean the carburetor of any build-up and/or corrosion that has settled in the carburetor bowl. The carburetor is between the air filter assembly and the main engine block. When in doubt, trace the fuel line from the gas tank, and it will lead you to the carburetor. Next, grab the necessary tools and start by turning off the fuel and draining the carburetor. The fuel valve is typically inline with the fuel line. To drain the carburetor bowl loosen the screw on the bottom of the carburetor bowl. Once the last drop is out, then unbolt the carburetor from the engine block. With the carburetor off and parts labeled for easy re-assembly, you then have to remove the fuel bowl. This will either unscrew as a whole from the carburetor body, or have a central bolt that has to be removed. When removing the bowl, PLEASE be very careful and mindful of the fuel float and the filling pin. With the bowl safely off, inspect it for fuel build-up and rust/corrosion. If there is either in the bowl then this means you need to grab a fuel safe cup and an old toothbrush and carefully start cleaning the bowl and the surrounding parts. If you are comfortable with small parts at this point, then carefully remove the fuel float and the the filler pin underneath it. Please take note on how this dis-assembles to ease re-assembly. Clean these parts as well with the clean fuel and toothbrush. Assemble the parts back together once you are sure everything is clean and put the carburetor assembly back onto the engine block. Once everything is tightened down, it is time to turn the fuel back on at the valve on the fuel line. With the fuel back on, hit the prime button 3-5 times and crank the engine over. If the engine doesn't turn over at this point, then there is a much deeper mechanical issue that requires a trained mechanic to fix. Most mechanical fixes at this point are not worth your while and you may save money by purchasing a new engine/generator. Please let me know what you find during diagnosis, and I can provide more help.
Posted on Aug 27, 2011
Honda Harmony II HRR216 won't start
Check for spark of smell of gas on the plug when you try to start it. That will tell you if it is fuel or ignition
May 18, 2013 | Garden
2005 ford five hundred engine turns over but won't start
do you know if you are getting gas. is there a buzzing noise in the gas tank when you turn the key. is there spark at the spark plugs. if there is not spark then you may need a crank position sensor. I am a self employed mechanic and I am on face book
Oct 31, 2012 | Ford Cars & Trucks
Can't get the power washer to start . replaced spark plug new oil and gas .get nothing Help!!!
are you getting spark?did you leave gas in it from last year?gas is only good for 30 days in small engines
Aug 02, 2012 | Garden
I have a Craftsman 2-cycle blower/vac and its only 3 years old and have changed out the spark plug and fresh mixed gas and still won't start. I need some help anyone know?
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Sep 18, 2011 | Craftsman Garden
Ran last year, won't start this year. Changed fuel and replaced spark plug. Checked spark and attempted to start with battery and tried with pull cord but no start. pulled plug and it had fuel on it so...
It might have tipped over on its side. Look at the air filter, if you see oil or gas on the filter then you might have to remove and clean the carburetor. I would start by cleaning/replacing the air filter and trying it again. If its getting fuel and the spark plug works then the only other side of the fire triangle is air.
Jun 05, 2011 | Ryobi Backpack Blower 25.4cc
2001 ttr 225 bike sat all last year. Would start this spring but not idle. Now it won't start. I know the carb had old gas. Where can I find a manual so I can take it apart and know what parts to...
Start by removing and cleaning the carb, it may not need any parts.
also change the oil, fit new air filter, new spark plug, and check the valve clearances
May 27, 2011 | 2002 Yamaha TT-R 225
TROUBLE STARTING BIKE HELP
If the spark plug is not getting a spark then you will need to replace the starting coil! the bike wikk start then !...Is the engine getting fule?
Dec 17, 2008 | 2001 Yamaha YZ 426 F
Coleman Powermate Powermate 5000W Generator Logo
206 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
