Question about Toshiba Computers & Internet
Can I connect my Toshiba NB 205 to my TV to watch etflix movies? the netbook has a VGA out, and the TV has S-cable and HDMI inputs. Thanks!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 135 Answers
Interfaces 1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x Microphone - Input - Mini-phone 3.5 mm , 1 x Headphones - Output - Mini-phone stereo 3.5 mm , 3 x Hi-Speed USB - 4 pin USB Type A
The above interfaces are in your laptop. There is no S-cable or HDMI interface.
If your TV have VGA port you can connect your TV to the VGA port in laptop. This will alow you to convert the TV as monitor.
Posted on Jun 01, 2010
How do I use a USB to watch a movie on Toshiba TV? Or hook computer up to TV to watch it?
Hi
Most recent laptops come with a port to connect to a TV, depending upon the input ports the TV has. The two most common are VGA and HDMI, and you will need to check which of these each item has. It is then simply a case of getting the appropriate cable to connect the two together, and then on the TV select the input from the menu, and on the laptop, make sure that the external video port is active (usually a Fnct and "F" key - eg Fnct + F5 for a Toshiba Satellite Pro U200).
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 08, 2015 | Toshiba Televison & Video
How do I connect my laptop to my led tv?
Is there a HMDI output on your Laptop or a VGA output. Some TV's have a DSUB input source that allows VGA depends on your laptop it could be HDMI if so TV should have an extraz HDMI input on the back and you change the source input on the TV to the HDMI 2 or HDMI 3 source depending on where you plugged in the P.C. . If HDMI you need to buy a HDMI cable.
Sep 08, 2014 | Toshiba Satellite Computers & Internet
How do I connect my toshiba laptop satellite c665 to my panasonic viera th-42pa60a when my hdmi input doesn't work. I want to stream movies.
If your HDMI output doesn't work you may have to use a VGA cable to connect to the VGA port in the back of your TV. There won't be any sound so you'll also have to get a stereo cable and connect that to your laptop and to the audio input on the TV
Oct 25, 2013 | Televison & Video
What tv cables work with HP 6510b please?
You will need standard HDMI only if your laptop have HDMI port. I think hp 6510b not include HDMI port. It has VGA and SVEDIO Output. Your toshiba TV have many PC INPUT Ports such as
S-Vedio, D-sub , VGA like old Desktop PC connection with Projector). So buy VGA cable or S-vedio Cable, then you can connect.
Jul 24, 2013 | Computers & Internet
Acer support
Use the VGA and set the TV to VGA as well.
Oct 15, 2012 | Acer Aspire One D255E13438 Netbook
I want to connect my computer to my Vizio TV to watch movies via netflix on my TV screen. If HDMI on TV end, what connection do I need to connect to the back of computer?
What "video-inputs" does your TV have:
* composite video (single cable for video, two cables for LEFT/RIGHT audio)
* component video (RED/GREEN/BLUE cables for video, plus RED/WHITE cables for stereo audio)
* DVI or VGA input
* HDMI input
* S-Video (similar to PS/2 keyboard/mouse, in size, and "round" shape)
What outputs does your computer's video-card have:
* composite (post-and-ring)
* S-Video
* DVI
* VGA
* HDMI
Just match them up.
Feb 24, 2011 | Computers & Internet
WHAT TYPE OF CABLE DO I NEED TO CONNECT HP NC6400 LAPTOP TO HD TV TO WATCH MOVIE ON TV FROM LAPTOP? VGA TO HDMI CABLE? THANKS
Hi.
The best way is to get a s-video converter to connect your round s-video computer output to your HDMI port on your tv. This is the best you can do according to your laptop connections. You will need a s-video cable, HDMI upscale converter box and HDMI cable.
The other way is to plug a VGA cable to your tv VGA port if you have one.
VGA to HDMI is also possible with a converter. A standard VGA cable with a HDMI plug on the other side will not work because your computer sends out an analog video signal and HDMI is digital only.
Hope it helps!
Feb 08, 2011 | HEWLETT-PACKARD HP NC6400 Core 2 DUO T5600...
I own a Toshiba NB 205 Notebook PC. I connected my flat screen TV to the notebook so I can use the TV as the Toshiba's monitor. I purchased a male-to-male VGA cable and plugged it into the VGA port on...
you need to tell the computer to move the signal over ---look for a picture of 2 tv screens on the laptop usually F5 or F8 (use with Fn key)otherwise right click on the desktop>choose PROPERTIES>SETTINGS
Jan 01, 2011 | Toshiba Computers & Internet
I would like to connect my toshiba tecra to my Sharp lc-46d62u TV to watch downloaded hd movies
Hi there if ur looking to connect ur PC to ur TV u must have one or two things an HDMI cable and an HDMI port on ur PC or a VGA cable and port on the TV and PC depending on the two it will be easy both ways however if preferred HDMI is the way to go due to audio is also carried over HDMI as well the video
Dec 27, 2010 | Toshiba TECRA M5 IC2D T5600 1.83GHZ, XP...
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
940 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
