Question about Kenmore HE2 Plus Front Load Washer
Front load washer problems
It's making loud banging noises and it's not getting all the water out during the spin cyle
  • 327 Answers
Hello,Most likely this will be the drum bearings.
Bearings normally last quite a long time but some will fail sooner than others. Quite often bearing failure is due to a faulty drum shaft seal which allows a small amount of water through and in to the bearings. The bearings then start to rust, which then accelerates the wear on the bearings.
Thanks
Posted on May 31, 2010
How do I check the belts or springs holding the washer tub
to check the belt or Air shock , its easy to remove the rear access panel , you can have a look for shock and motor & belt but there are a lot of reason for your complaint for doesn't spin out water and noisy when spinning it may be have kinked in the drain hose or the spin start before pumping water out properly leads to load unevenly distributed in the movement of the drum, so i believe that your problem in pumping the water out. Alaa Refaei
Mar 04, 2014 | Frigidaire ATF6000ES Front Load Washer
Maytag neptune front loading washer
What is the model # of your machine???? The loud banging noise sounds like the loads were getting unbalanced. This is the most likely since i have no problems with the suspension all of a sudden not stabilizing tub properly. If the washer was moved or transported than that would make more sense to me. please provide as much info as you can. Try doing a load of 10 towels. Let me know how that does and with the model # i can help with pulling some diagnostic codes
Oct 02, 2007 | Maytag MAH6500 Neptune Front Loading...
Load noise and will not spin out clothes
Good Morning PJ, this is AP with Electrolux.
Thank you for submitting your question concerning your Frigidaire front load washer, ATF6000ES. Typically if your washer is making a banging noise it could mean one or two problems, but primarily the tub is off balance or your washer is not level. In this regard, since the tub is spinning it would be advisable to reach out to a local service provider to properly diagnose your washer. You can often locate a qualified tech through the manufacturer website.
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Loud banging noise during spin cycle of my front loading kenmore
If you spin the drum by hand, does it make any kind of thumping or banging noise? If it does, then you probally have a broken spider arm(s). This is very expensive to repair, unless you are handy, it may not be worth fixing. The link below shows the problem and how it can be fixed.
http://www.jimwilliamson.net/misc/2006-08-28-front-load-washer/index.html
Dec 23, 2009 | Kenmore Washing Machines
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore HE2 Plus Front Load Washer Logo
245 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
