Question about 2wire Wireless-G 802.11g ADSL Gateway
My modem will not give a signal even though it is hooked up write
    Problem Solver:
  • 10 Answers
Log on to the modem setup page using the default gate and check if Broadcast SSID is checked
Posted on May 31, 2010
How to make my modem give out wifi?
check if your modem is cable in broadcasting wireless signal. if you can see wireless light in front of the modem then your modem is a router as well but if it does not have wireless light then you need a router hook up to it
Sep 04, 2011 | Arris High Speed DSL Modem
I have a Linksys modem with a netgear wireless router. The other night my internet just stopped working and now it is though the modem is not transmitting a signal. I have connected 2 different computers...
the ds light is for downstream which is your digital signal simply put...... if the light is not going solid to denote being :"online" there maybe signal related issues. rain will mess up the cable signals as the service is exposed to elements etc.....here is a trick i do with a modem that doesnt want to lock on to good signal.....reboot the damn thing...........give it a minute or two.. if the online light doesnt sync up solid....unscrew the cable connector on the back of the modem while it is powered up and wait 15 seconds////then screw it back on (needs to be hand tight, its like a water hose, if its loose you get signal loss) and give it 10 minutes......if it still doesnt lock up and go solid indicating online then call your cable company, you should not get charged for their service not working correctly..........it then would be something only a tech could fix. but if it does lock up and go solid ....hook up your router , power it up and give it a minute to sense the modem, restart the computer and you should be good to go...
Jan 21, 2010 | Linksys WCG200 Wireless Cable Modem 54G...
Can't get a signal even though I have hooked up
There were four coaxial cable connections. One turned out to be bad. Once redone, the signal picked up loud and clear
Oct 05, 2009 | Standard Horizon QUEST GX1255S CB Radio
The router is running fine all hook ups are fine changed the wireless card took that to a computer place and it was running fine at the shop when I got the pc home unable to access the internet even though...
The cable internet is not "seeing" the computer. The router is blocking it. That is why it works if you plug it into the modem directly. How to solve this is to turn everything off and unplug power to modems and routers for 3-5 minutes. Then replug in routers. Then restart computers.
That is why it worked at the computer store. Everything was shut down and restarted.
Also, sometimes it is necessary to call the ISP (for example Comcast) and have them re-send the signal. Also going to Control Panel Network Connections and choose "repair the connection" will reset the signal.
Be patient it will work.
Aug 15, 2009 | NetGear RangeMax WPN824 Wireless Router...
My ps3 is int able to detect my ip adress
once you connect to the modem you must reset the modem, unplug it for the power source for 2 whole minuets then reset the ps3 and this should solve ur problem
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
Low signal(wireless MAXg ADSL Gateway USR9108)
1.TRY siting in a place wth less people ... actually wth my USR9108 i get disconnected even if some one is standing infrront of the modem so stay in a open place wth less people.
2.RESET your modem 3 tymes and configure ur modem by the settings given from the Telecom company.
3.Check ur modem antennae ... bcoz its modem is very FRAGILE... it sometimes have an internal wire break ,,,,
TRY installing ur BRothers antannae on ur modem nd den use it....
ALI KAZMI
May 01, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
I have no computer or cable and need to set up internet on my PS3
??? A router will NOT replace your modem; the router won't work without the modem. If you're going to give advice, please make sure it is somewhat correct.
Okay. So first you need the telephone cord to go from the phone jack into the DSL port on your modem. Then you need the Ethernet cable that came with your modem (looks like a phone cord but much bigger) to go from the ethernet port in the back of the modem into the wan or internet port on the router. Verify that the DSL and internet lights are on on the modem.
For the rest of the setup, watch this . It will walk you step by step in connecting your PS3 to the wireless internet. Thanks and please take a moment to rate as fixya.
Feb 04, 2009 | Sony Playstation 3 (PS3) Console
Vonage customer, problem running through home phone wiring
Make sure you have disconnected the original phone line at the first entry point to your home. Even though regular phone service is disconnected (software) the original phone line carries some "noise" which can cause issues when trying to utilize existing phone wiring throughout the home.
Dec 02, 2008 | Lands Phones
DI 624- Cant connect from router to computer
Hi mark - please don't rate this til it's fixed. Hook it up the way you had it. i.e. modem>router>pc. Try it, probably won't work. Unplug the power on your modem and the router. After 60 seconds plug in your modem. When all the lights return to normal (except the activity light), plug in your router. Give it 20 seconds or so. Try it and let me know what happens. Thanks.
Jeff
Aug 24, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
Jan 14, 2008 | Westell Wirespeed VersaLink...
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
83 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
