Question about Mtd Garden
Bolens MTD lawn tractor with transmatic shift on the go trans goes into reverse ok but will not stay in forward
    Brigadier General:
  • 3,917 Answers
Thanks for contacting Fixya.com
First you need to inspect the traction belt that drives the transmission.If it is on all the pulleys and is not damaged then probably have a problem inside the transmission. That belt should be tight unless the clutch/brake pedal depressed.
Let us know if you have something more to know else please accept the suggestion.
Thank You.
Posted on May 31, 2010
  • 2,427 Answers
Hmm well this could be a simple thing as a bushin,, to damaged clutches in the transmission.. In eighter case a mechanic (repair man ) will need to take a look at it.. Maybe another expert here will be able to talk you through a fix,,
How can i cut autoshut-optioin when blade is rolling and i want to rewerse. Because i have that kind of garden that i must reverse a lot.. I have MTD Mastercut 96
CHECK under the mower where forward and reverse lever goes down to the trans axle. you should see a wire unplug it
Oct 17, 2013 | Mtd Garden
Bolens 13ac762f
if blades are turning mower is cutting better to go forwards though
Sep 11, 2013 | Mtd Garden
Cant get gear i to reverse on my Murry riding lawn mower
is your belt to tight? that will cause tention on the trans. and it wont go into reverse try it while its moving forward jerk it into reverse and see if it goes may be just hung between gears
Jun 29, 2013 | Mtd Garden
Change PTO cable
Here's a link to the owner's manual:
http://needmanual.com/dcicd-download.php?dcdnd=MTD-760-77-Transmatic-Lawn-Tractor-Mower-Owners-Manual.pdf&drl=http%3A%2F%2Flawn-garden.needmanual.com%2Fmtd-760-77-transmatic-lawn-tractor-mower-owners-manual.html&dcid=fdfce93131e03bb50b4552b64f18a331
Here's a link to the parts manual: Just above the title on the document is a link that allows you to download the PDF document so you can read it. On page 14 in the circle is what I think you're looking for.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/mtd/13rn772g729_mtd_transmatic_lawn_tractor
Sorry I can't help you more. I'm really not familiar with this tractor. Mine has an electrical clutch to engage the blades. Hopefully this will help.
Jun 15, 2012 | Garden
I have an MTD mower tha tis ver jerky in forward, reverse is fine. What could it be? The trans is about 2 years old. I thisnk it could be the clutch plate or the differentital, however, reverse works fine...
Assuming that the model you have is a single speed transmission with variable speed belt system and that the mower has never been used to tow anything heavier than a dump cart. 9 times out of 10 its usually the forward gear shift key not allowing it to go all the way into forward gear. Might be able to ajd the shift linkage to acomodate a tighter mesh with the input and ring gear
Nov 23, 2009 | Mtd Garden
Shuts down in reverse
I'm not familiar with that particular mower but I'd bet it is a direct switch. Follow the shifter arm down and you should see a arm or button that arm contacts a switch when you put it in reverse. pull the two wires off that switch, put a wire in between to connect them and it is by-passed.
Please rate if this helps-
Mar 22, 2009 | Mtd Garden
Garden Logo
222 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
