Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Magic focus i cant get my blue line to line up they have downward swirl and will not move up or down but will move side to side. the swirl is at the top and gets somewhat lined up in the center and start swirling the other way towards the bottom
  • okeedokee33 Jun 06, 2008
    How do i get a convergence Ics for a hitachi 51f500, i beleive youy post that, that is what is wrong with my tv as well,
    thanks.
  • LimboMom Jun 10, 2008
    Hi, single mom/3 kids/2 jobs here, would love to know where to find the replacement lcs and tech support! I think mine has a convergence issue too - my pink and green have gone out of focus with each other, mostly near the top of the screen. While I fear I can't afford hundreds of dollars for repair, I certainly don't have hundreds more NOT to repair it and get a new TV. Many thanks for any help!
    LimboMom
I have a similar problem only in my case it is the green that will not focus.... The picture is fuzzy and has a redish hue to it. Very weak green colors in the picture.
Posted on Jun 02, 2008
Could you post where you can buy the ics ,The red is out of focus and the magic focus want focus it.
Posted on Apr 19, 2008
  • Hitachi Master
  • 8,617 Answers
You need to replace the convergence Ics thats why youre unable to align the blue. If youd like me to post a link where you can get replacement ICs as well as free tech support and instructions let me know and I will post the link.
Posted on Apr 08, 2008
The tv scren is wavy on the left side but the screen is still visible on the right should I use the magic focus button
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 11, 2010 | Hitachi 51SWX20B 51" Rear Projection...
Lookslike the picture is in 3d and when i try ti use magic focus
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 02, 2010 | Hitachi 57F500 57" Rear Projection...
There is a line right in the middle of the tv going vertically.. the left side is fine but the right side is like 3d tv.. why is that.. Model # WD-62628--- S# 117086... Mitsubishi
  • Screen looks 3D
May 24, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Convergence is off
YOU DEFINITELY NEED TO CHANGE THE STK IC'S THE ONE THAT CONTROLS YOUR BLUE COLOR IS OUT BUT CHANGE BOTH THE RED AND BLUE OR ELSE IN THE NEAR FUTURE THE RED WILL BURN OUT ALSO. THESE IC'S ARE IN THE VIDEO BOARD USUALLY AND ARE ATTACHED TO AN ALUMINUM HEAT SINK. CANT MISS THEM THEY ARE PRETTY BIG AND ARE SIDE TO SIDE.
Jan 28, 2010 | Hitachi 57F510 57" Rear Projection...
Colors do not line up on my tv ( left side of sreen looks like 3D) digital array "+" are only white on right side.
  • Screen looks 3D
Jan 11, 2010 | Hitachi 50FX20B 50" Rear Projection...
Hitachi 51F500 magic focus wont work, blue has "dropped", when I use the magic focus on auto it does nothing, when I use manual focus the grid has the blue scooped down and I can't seem to get it back in...
Sounds like your blue convergence module is faulty along with a few resistors. There is two convergence modules in your set(stk-392-020) and when one fails, the both of them are usually replaced with a matched pair .If you have a good knowledge of electronic you may replace them yourself.otherwise you`ll need the help of a tv repairman. Hope this help. Good luck
Nov 17, 2009 | Hitachi 51F500 51" Rear Projection...
Blue lamp is not in focus
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 05, 2009 | Hitachi 46F500 46" Rear Projection...
Have a 53" Hitachi HDTV that bows at the top and the bottom. I was told one of the transitors or transformes blew. I also do not have the regular magic focus just the static focus now. I tried to alli
  • Screen looks 3D
May 03, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Magic focus off
You will not be able to solve this yourself. It needs the convergence IC's replaced which is a big job.
Mar 30, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Convergence Problem
sounds like 1 of the convergence chips are gone theres 2 of them and better off replacing both as the other would just go a month down the line there might also be a resister or 2 gone, the price for that kind of job is around 150 +vat.
hope this helps
Feb 10, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
151 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
