Question about Kenmore Sewing Machines
I inherited this machine so i dont have manual.model is kenmore 17600. worked fine then it got sick. thread wont stay in needle, wont sew stitches in fabric, and what should dials be set at for tention etc..
  • klemery35 May 31, 2010
    thanks for your help. was getting very annoyed
    President:
  • 1,194 Answers
You will find all the necessary information regarding your above stated problems in the manual itself under troubleshooting.
To download the manual, visit this link.
Thanks for using Fixya.
Good Luck and have a nice day.
Posted on May 31, 2010
Do i need cam to do zigzag stitch on Kenmore 158.17600
This video will probably be handy, although not quite your model, it should be very close. Generally, your machine should be able to do straight & zig-zag stitch without cams. Cams were usually for decorative stitches.
Kenmore 158 17550 Sewing Machine Tutorial
Parts: https://www.sewingpartsonline.com/kenmore-158-17600-sewing-machine-parts.aspx?sort.ss_cat_sort=desc&index=64
Manual: Kenmore 158 manuals 3
Jul 20, 2018 | Kenmore Sewing Machines
My sewing machine will not stich. i have tryed everything i can find on this problem but nothings working
Make sure nothing has either gotten stuck/caught/jammed somewhere inside it. Insure that the thread stays attached to the needle. Or the material you are trying to sew/stitch may be too thick.
Nov 17, 2012 | Singer Sewing Machines
Singer esteem ii wont sew after the needle wouldnt go down and got fixed. when it does sew it skips stitches. what do I do?
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
if you can send me the model number of the machine,, I'll see if
singer has a free downloadable manual
Sep 11, 2012 | Singer Sewing Machines
My Kenmore stopped making stitches. I changed the needle recently to a Singer Universal regular point needles 100/16, but I dont believe that is different than what was in there before. I have a Model...
Why are you using #16 needle, that is very heavy duty? Did your machine pick up the bobbin thread correctly? Try a different needle, #11, (inserted facing away from you) is usually good. Make sure that you have decent thread and that it is the same weight top and bottom. Now rethread, with the presser foot up and when you have that done, with the presser foot stiil up, pull top & bottom thread, it should feed smoothly, now with the presser foot down, pull the thread, it should barely move. This usually seats the thread in the tension discs. Put your top tension at 3 and see if that makes a difference.
Jan 19, 2011 | Kenmore Sewing Machines
I have a kenmore 385.1884180 sewing machine. The other day I ran a couple of seams to see if the machine still worked as I have not used it in a few years. And it stitched just fine. Today when I go to use...
Make sure that you are doing the bobbin right, by that I mean, make sure that the thread is in the tension spring and you put your finger on the bobbin and pull the thread up, now bring down your needle to hook it. Look at your manual. If, you don't have your manual, go managemylife.com and download for free
Jul 18, 2010 | Kenmore Sewing Machines
Sewing machine not stitching
Sounds like you need to retime the machine, if you email me I can attach instructions drivewithken@blueyonder.co.uk
Jun 26, 2010 | Kenmore 15212 Mechanical Sewing Machine
Top thread tension tight
March 12, 2009
kenmore 385.17922
i have started using my machine again (after several years) and am doing patchwork.. all has been fine, and suddenly the bottom thread (bobbin) is looping. i've adjusted the tension nob from 4 (where i had it) to 5...back to 4.. 41/2....3 1/2....5 1/2... on and on and the bottom thread still keeps looping.
i've read and re-read the manual...and the only suggestion it gives is to adjust the tension button.
it's not working...... what else can i try??
thanks
eva
Mar 11, 2009 | Kenmore Sewing Machines
Thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Nov 04, 2007 | Necchi 4595 Mechanical Sewing Machine
Machine wont pick up bobbin thread
needle won't pick up thread I think the timing is off, how do I retime it?
Aug 25, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
