Question about One For All URC-3605 Remote Control
Code to activate
Trying to activate a remote for a misakai tv and need the codes to get it working.
    Genius:
  • 1,274 Answers
You will have to do the CODE SEARCH on this one,..Press TV once on the remote, press and hold the SET button until the LED blinks twice then release it, enter 9-9-1. The LED will blink twice, Point the remote at the TV and slowly alternate press between TV and POWER buttons, stop when the TV turns off after pressing POWER, if it does not have a POWER button, you can use 1-2-3, CH+ or PLAY. to lock in the code, press and release SET....hope this was helpful...
Posted on May 31, 2010
Have a RCA system link 3 remote need codes for a Misakai tv vcr combo model mtc 1301 ?
0221 0247 0324. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Try a search by type in the brand name of your TV to the search box.
Sep 24, 2014 | Televison & Video
Need codes for remote to set for my used tv it is a misakai this code i have will not work
I am not 100 percent on the site name but I believe it is "universalremotecodes.com" That search will at least get you close. They have most codes out there and easy to search through.
Jun 15, 2011 | Televison & Video
Hi i have A Misakai t.v. model-MTV2002 I'VE tyred all kind's of universal remote's cannot find out no t.v code for a universal remote can u help i'm lost thx-u number's & stuff about this company...
Hi Dennis
Your TV is made by Funai Corp. of China. They make many brands of TV and many are identical inside and just have a different badge/casing.
http://www.funai.us/index.html
You didn't state which brand/model remote you have so I can't offer any specific codes, however, if you try codes for some of the other brands manufactured by Funai - see following list - you may get one that works:
Funai
Magnavox
Symphonic
Sylvania
Superscan
Element
Philco
Durabrand
Trutech
Emerson
ESA
Personally, I think Funai, Sylvania and Emerson are the most likely. Try these and if you have no luck, post back with your remote model number and I'll see what I can find.
Regards,
BElectric
If your problem has been solved, please be generous and award this solution 4 thumbs-up. This service has been provided FREE - your simple acknowledgement is appreciated. Thanks.
Nov 08, 2010 | Televison & Video
I have durabrand tv dwt1304 and magnavox CL403 remote, I need a code
There may not be a code set that applies to your TV' there is no such thing as a 'universal' remote and the farther apart the two are in time, the less likely it is that you will find a code set that works. A new remote is more likely to have a code set for an older TV but the reverse is not possible.
Your Durabrand AND the Magnavox are both made by Funai so check their website for info on both.
You might also try the brands listed below to see if any of their code sets work, all are made by Funai:
Funai, Symphonic, Sylvania, Emerson, Aventura, Durabrand, ESA, Magnavox, Insignia, Philips and Misakai
BTW, when buying one of the remotes claiming to be 'universal,' check the remote manufacturer's website by model number BEFORE buying it to see if they have those devices listed you want to control.
Good luck-
Mar 22, 2010 | Durabrand DWT1304 13" TV
Need a remote control code for philips tv vcr combo ccc090at as a result of the Comcast dta conversion from analog to digital. I have tried the combo codes 20035, 20081, and 200618. Plus I have tried...
That unit may have been built by Funai, the poorest of the Japanese electronics companies.
You might try any codes you find for the brands listed below, all of which are made by Funai:
Funai, Symphonic, Sylvania, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, Philips and Misakai
Oct 25, 2009 | Philips CCC090AT 9 in. TV/VCR Combo
None of the remote codes given will work
The remote codes of what? Which remote? If you are trying to use a so-called 'universal' remote, it probably does not have the codes for this set.
Your set was made by Funai so you might try the codes of any of the following:
If you need the real remote for this set:
Remotes
Oct 24, 2009 | Sylvania LD195SSX 19 in. LCD TV
What is the tv and dvd code of misakai mtv1301 using a universal remote
I need to know what brand of remote you are using with the televison.
Then I will google "miakai remote codes" and will find your anwer
Jun 03, 2009 | Televison & Video
Need codes and instructions for Radio Shack 3 in one remote programming
First, you need to realize that there is no such thing as a 'universal remote.'  At best, they are multi-brand remotes.
You might get lucky if you try any codes you have (or can retrieve from the Tandy website) if you check these brands too:
Funai, Symphonic, Sylvania, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, and Misakai
They are all made by Funai, one of the worst manufacturers in Asia.
May 17, 2009 | Durabrand DWT1905 TV
Cannot find remote code for a Misakai TV model number 1301.
Hold code search until the light stays red
then
click TV
then
click CHANNEL UP
then
once your t.v. responds (by the channel going up)
click OK.
Your remote is now programmed.
Oct 18, 2008 | Televison & Video
One For All URC-3605 Remote Control Logo
331 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
