Question about Plumb Pak & Triad Bath Drain
Do i use a washer between the tip toe assembly and the tub
  • 349 Answers
Use plumbers putty between the assembly and the tub on top. Use the rubber washer underneath to mount up to tub.
Rubber washer on top may work but due to hot temperature water it would cause the rubber to loosen up and cause a leak.
Posted on Jun 07, 2010
Toe tap drain leaks down the drain
sounds like the rubber seal is leaking replace the rubber washer
Dec 28, 2013 | Delta Rp31558pb Classic Toe Operated Tub...
We have a toetouch sch40 bathtub drain that leaks. We want to take it apart to check the gasket or put silicone around it to see if the leak will stop but can't take the drain apart.
DONT SILICONE IT what you did not say is where it was leaking. So lets look the two things that could leak.
If we are talking about the water leaking out while you are taking a bath you need to take out the center section of the tip toe and replace it. You can buy a new replacement at any store that sells tubs and plumbing fixtures.
Now one of the things you might have trouble with is getting the tip toe top out. Take a channel lock and grab the whole top now use you muscle. Now turn it counter clock wise it should come out.
Just screw in a new one.
Now if it is leaking under the tub you have to do the same as above and now you have to remove the other section of the drain. You will see a "cross" with the hole that the tip toe screws into this will take a tool called a *********. Just line up the bell with the cross and it to turns out counter clock wise. Clean it and install some new putty and put it back the way it came apart.
Thanks for using us, and be safe while you work
Tom
Also if you could take a second to rate us it will help us serve you better if we know we are talking a way that you can understand.
Sep 10, 2011 | Moen 101652___ Bath Tub Drain Assembly,...
Water wont go into the machine but yet all the lights are on
It sounds like you have a hose leaking.You can check the hose leaking by opening the washer door & inspecting the rubber boot that goes around the perimeter of the tubs. It is secured in place by two clamps.In order to check if the leak is underneath the washer tub you will first need to disconnect electrical power to the washer.Remove the three screws securing the toe panel to the front of the washer and remove the toe panel by lifting slightly and pulling forward.
Hope this helps.
Shane
Apr 22, 2011 | Indesit W 123 Front Load Washer
Water is on but the tub will not stay full
Hope this helps.
Shane
Mar 10, 2011 | Whirlpool LSR5132PQ Top Load Washer
Washer is leaking from door, the other day the rubber gasket between door and tub came off during use..we put it back on, but it still leaks
Hope this helps.
Shane
Mar 08, 2011 | Kenmore HE2 Plus Front Load Washer
When fill the water it goes to out hole if machine not switched on
Hope this helps.
Shane
Feb 12, 2011 | Whirlpool WTW5500X Washer
Door locked.... tried to unplug and cancel button - still not open??
Try holding end cycle button for 30 seconds if no. Then try reset process Press "Pause/Cancel" two times to cancel the cycle. Press "Drain/Spin" if there is water in the tub. Unplug the or disconnect power for two minutes, then plug the washer back in or reconnect power.If no then here is the manual open process. Unplug the power cord of the washer from the outlet. Locate the toe panel. This is the section of metal at the bottom of the front of the washer, directly below the door. Remove the three screws on the bottom flange of the toe panel, which connect it to the washer. Lift the panel slightly and pull it forward to remove. Manually unlock door Reach up inside the front panel and locate the door latch assembly on the right side of door.Feel for a tear-drop shaped tab on the bottom of the door latch assembly. This tab will manually unlock the door.Gently pull down on tab about 1/4 inch or until you hear a click. The door should open.
Dec 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
During spin cycle washer drum knock and seems as if it is out of balance, even when empty
"spider" broken. Cast aluminum bracket that attaches shaft to inner tub is coroded. Spin tub and shaft assembly cost approx $300 to replace. Heard that parts may have lifetime warranty.
Sep 03, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer will not drain water out
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To manually unlock the door lock system, perform the following steps:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a teardrop shaped tab. Gently pull the tab down approximately 1/4 inch, or until a click is heard.
5. The door may now be manually opened.
Pl rate me nice if helped, thanks.
May 12, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Water has started pouring out from under my washer
Hello, you've indicated this problem only arrises during the rinse cycle, is that correct ? The leak doesn't occur during the wash cycle initial fill level ? I want to distinguish the difference because there has been a repair tip issued by whirlpool for the duet and sport washer's. This may be applicable to your machine. If it is indeed only during the rinse, the problem is within the door assembly. Specifically the glass and it's "seat" to the frame. Let me know, I'll watch for your reply. macmarkus :)
Mar 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Plumb Pak & Triad Bath Drain  Logo
94 people viewed this question
Top Plumb Pak Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumb Pak Plumbing Expert? Answer questions, earn points and help others
