Question about Kenmore 75962 Gas Dryer
Wont heat up
Dryer unit will not heat up to dry clothes
  • Kenmore Master
  • 43,501 Answers
Hi, If you have a gas dryerwont heat up - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 08, 2010
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
My Whirpool Gold dryer is heating up to dry the clothes, but the clothes are damp /wet.
Hello
When the dryer wont heat up and dry clothes it means that the thermostat/thermal fuse is bad and needs replacement. This part is located on the blower wheel housing inside the duct, please get back to me if you have any other questions.
Kevin
Nov 20, 2010 | Dryers
Gas dryer wont dry close
replace the gas valve coils. they sit right on top of the gas valve. they are black and round, and clide down over a shaft. remove screw from plate holding them, and slide them up and off, replace, and it will run....turn gas off while working on unit:)
Sep 16, 2009 | KitchenAid KGYS750LQ Gas Dryer
Whirlpool LEN100PQO electric dryer wont shut off/no heat
if your thermal fuse is blown you will not recieve heat. if you put your dryer on sense load it will keep running because it is not sensing that the clothes are getting dry which in return your timer does not
advance
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Machine wont dry my clothes
Gas or electric? Gas - Igniter unit needs replacing. Electric - Heating element needs replacing
Apr 15, 2009 | Dryers
No heat
ok so you have some heat.your dryer unless an ge one has one element so if you have heat its working.then what you have is an exust problem.once you heat up the clothes and cause the moisture to evaporate then it must be able to leave the dryer or it reclings to the clothes,hence lond dry times.to test this dry a load with the venting undone and the dryer pulled out.dont worry it wont start a fire/never!its about 180 degress to 130 of moist air. if ok then confirms that venting is blocked.some times dryers get blocked internaly also but do the other first.God bless,tom
Jan 01, 2009 | Whirlpool LER4634J Electric Dryer
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Kenmore 75962 Gas Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
