Question about Canon ImageRUNNER 1670F Copier
I can't find the counter that tells us the number of copies the machine has done.
  • 149 Answers
You should press the button marked '123'
Posted on Jun 01, 2010
How do I check the number of copies the photocopying machine has made (Sharp 5620). Thanks
Download User manual, page 121, CHECKING THE TOTAL OUTPUT COUNT AND TONER LEVEL.
Hold down zero Key and display will tell you 3 + 3 numbers of counter. (audit mode is off)
Sep 03, 2016 | Sharp Office Equipment & Supplies
Hi dear sir I have Ricoh 700 machine it was working fine but yesterday it's got some problem when I switch on its showing ready when i make the copy its scan the paper but not print stay on same place but...
You should try resetting the machine if you can. Taking out power cord will not reset machine. The micro chip has to be reset on the machine. If test / counter print works but copy doesn't work, then reset machine.
Nov 26, 2014 | Office Equipment & Supplies
WHY OUR MACHINE Di2011 DEVELOPER AND DRUM ARE BRAND NEW. BUT STILL BRINGS PROBLEMS E.G SERVICE CALL AND MACHINE TROUBLE SHOOT.
Was the counters cleared first? for the drum and developer, has to be done because the machine uses the counters to tell the copier what voltages to apply to certain assemblies. If not done causes codes and image problems. That is also how the copier has a new drum and developer, after the drum and developer where replaced was Toner Density procedure run. And no prints copies or faxes where received after the developer was replaced and running the Toner Density procedure, and any did get ne developer and start again. Must disconnect network cable and fax cable before changing developer also.
Jul 01, 2014 | Konica Minolta Bizhub c203 Copier
I have Bizhub 600,when i make a copy, the Df, and scanner are working normally, after that you see in the screen (Read to accept another jop) and the machines does not copy please tell me what is the...
When is the last time a full PM was done. with the counter properly cleared and require procedures where done after the developer and drum are replaced, did you clear the counters for the new drum?? Replacing the heater (FUSER/FIXER is not the problem) A good cleaning in and around the Photo drum and developer section with the developer replaced and counters properly check and so get a qualified Konica Minolta Tech out to look at the machine. My recommendation
Oct 29, 2012 | Konica Minolta Bizhub 600 750 Image...
My Canon Pixma MP130 tells me my Waste Ink Absorber is nearly full. Manual tells me not to touch but how do I replace or empty?
This is a safety function that Canon ans Epson built into theyr machines. Normaly this problem can be solved by replacing the absorber pads (or cleaning them) however you will need a service mode tool to reset the ink count in the eprom. Search google for the specific tool for your printer.
Good Luck
Dec 09, 2010 | Office Equipment & Supplies
My copier just stopped copying. i suspect the counter
as i understand the pm counter am i right ? one more thing tell me what the machine model number so i can help you .... thank you
Dec 06, 2010 | Minolta Office Equipment & Supplies
Savin 9940DP ''Set Key Counter''
Key counters are used when a copy machine is set up for public use where copies are charged on a per copy basis. Key counters look like small boxes that plug into the side of the machine and they have a counter on them that looks like a cars odometer. A user plugs in the key counter, makes copies and then takes the counter to a register to pay for the copies they made. Sounds like that is what you have going on.
Nov 02, 2009 | Savin Office Equipment & Supplies
We have a 1025iF Canon copier. I'm trying to
hello.
the first counter 101 is total of the machine every paper that gets out of the machine(print,fax,copy,reports)and the 201 its only about copys.
Oct 27, 2009 | Canon Office Equipment & Supplies
HOW TO GET PAGE COUNTER IN KM-1510
Just hold down the stop/clear button for 3 seconds..
It will flash F24 then 3 increments then 3 more.. eg; F24>063>123
It means you have done 063123 copies/prints..
Sep 18, 2009 | Kyocera KM-1510 Copier
Thoshiba E studio giving the Total Counter 220320 number and display call for service. You are requested to advise.
The machine needs a PM which is a preventive maintenance overhaul. Contact a technician in your area or restart the machine holding down the 0 and 8 key and input code 252 and hit 0 and enter, then power down and restart to reset PM counter.
However, I HIGHLY RECOMMEND that you get a full PM done if you want to avoid future copy quality problems and parts ware-down.
Nov 16, 2007 | Toshiba e-Studio 350 Copier
Canon ImageRUNNER 1670F Copier Logo
old marine
old marine
