Question about Microsoft MNTR WISEWING|LCD19' 8MS DVI W902DB Monitor
Power on and it shuts down in about 20 seconds.
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 31, 2010
Grandson used pass word and forgot password, now I can't unlock tablet.
Try resetting it by holding down the power button for 10 seconds.that would shut it down. Restart then try logging in. Try to factory reset using the combination buttons as listed below
look for a tiny reset pinhole along the case it may reset the tablet too All RESETTING Ways Below Holding Down Certain Sequence of Keys or Buttons will put Most Tablets or Android Phones in Service mode to Factory Restore to New.
Hold Vol + & Power 20 sec
Hold Vol - & Power 20 sec
Hold Vol + - & Power 20 sec
Hold Home & Power 20 Sec
Hold Vol + & home & Power 20 sec
Hold vol - & home & power 20 sec
Hold Vol + - & Home & Power 20
Dec 12, 2014 | Tablets & eReaders
Will not charge
My grandson forgot his password for his Nextbook Tablet, how can I unlock the screen to rest his password.
Jan 11, 2014 | Nextbook Premium 8 Se Android
How do i factory reset my kindle wich is locked internaly
Hold the power button in for 20 seconds (count the seconds) and ignore any message you see about shutting down the kindle. after 20 seconds, release the power button and press it again. the kindle should reboot. Then go to menu, settings, restore
Nov 15, 2013 | Tablets & eReaders
Computer shouts down in 15 to 20 seconds after starting
The specs say the PSU is ATX compatible. Whether that is for the connector only or for the whole power supply is something you will have to determine.
If you have an ATX power supply handy (like in an old computer) give it a try. This one is only 300 Watts so it won't likely be expensive to replace.
Have a look at: http://www.techspot.com/community/topics/dell-dimension-1100-shuts-down-after-20-seconds.135987/
Aug 28, 2012 | Dell POWER SUPPLY Power Supply
Powers up no video shuts down
does the power light indicator blinks? or no power at all.
Jul 21, 2012 | Televison & Video
Runs for about 20 seconds then shuts off
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Jan 25, 2010 | Panasonic NN-H664 Microwave Oven
Alienware Aurora desktop crashes on bootup
try to change the cooling fan mayhbe its the problem that your proccessor is over heated.
Dec 25, 2008 | Alienware PC Systems Alienware Aurora High...
Kohler lp shuts down
What you need to know is there enough fuel going to the regulator. It should be 7 to 11 inches Water Column. If not your problem may be not enough fuel. That includes when the heater in your house kicks on and what ever gas appliance you may have. Once you verify that you need to figure out if you have the proper pressure coming out of the regular on the inside of the generator. Next I would look at compression of the cylinders. It may need new piston rings.
Dec 13, 2008 | Kohler 12 kW Emergency Power System -...
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Sudden shutdown / will not power up
try check your BIOS.Upon turning ON your laptop, press down the DEL button of your keyboard then check settings of your power.it maybe activated the standby mode by certain time.
Jan 17, 2008 | HP Pavilion ze2000 Notebook
Microsoft MNTR WISEWING|LCD19' 8MS DVI W902DB Monitor Logo
74 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
