Question about ViewSonic VX710 17" Flat Panel LCD Monitor
My viewsonic vx710 lcd monitor shuts off after @ a hour of operation then won't come on for @15 minutes
  • 11,361 Answers
Check the power supply section first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 31, 2010
Testimonial: "Thank you for your advice I couldn"t even find this monitor on their site,."
Yea my ViewSonic VX710 takes and it will flash on for only 1 sec. then it stays off. if it is that bad capacitor thing can u just buy new power supply? You can email me if that is easier. Thanks
Yes, do look for caps with bulging tops as shown in my pictures, you should replace them in a set.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX710_910/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 12, 2011 | ViewSonic VX710 17" Flat Panel LCD Monitor
Monitor turns on for one second then shuts off
Possibly failing power capacitors, needs to be checked by a TV repairman
Dec 30, 2010 | ViewSonic VX710 17" Flat Panel LCD Monitor
My Viewsonic 2235wm goes on and off frequently
Look for bad caps as shown in my VX2235 album.
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 25, 2010 | ViewSonic VX710 17" Flat Panel LCD Monitor
Viewsonic VX710 17" Flat Panel Display. It turns on and after 1 or 2 Seconds shuts the backlight off L.E.D. satys on but the backlight won't comeback on. No cap seems to be blown up.
Failed cap amy not show any sign of bulging or leaking, it can still have high ESR. You can also have components failure in the inverter circuits such as shorted inverter transformer driver transistors, open or short winding (DC Ohm test will not show shorted turn, need to use ringer test), I use SENCORE LC75 for testing, bad lamps or bad soldering works on the lamps. See http://s807.photobucket.com/home/budm/allalbums for some guide.
Mar 31, 2010 | ViewSonic VX710 17" Flat Panel LCD Monitor
You may have bad transformers, need to be checked, DC Ohms meter may not be enough, need to use inductor tester (I use Sencore LC75). You can also have bad lamps (bad solder connections). The caps may not have any sign of bulging but can have high ESR, see some pictures here for guide: http://s807.photobucket.com/home/budm/allalbums
Mar 30, 2010 | ViewSonic VX710 17" Flat Panel LCD Monitor
Monitor will not turn on
It could be bad caps on the power supply. Look for bulging caps and replace them if bad.
Sep 12, 2009 | ViewSonic VX710 17" Flat Panel LCD Monitor
Monitor is blinking out
Hi...there,
It's seems you got a busted backlight inverter problems...
Dec 17, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
Screen keeps blinking showing a anolog sign in the bottom right corner
Perhaps you are using the Blue plug (VGA) instead of the White one (HDMI)?
Chris
Water Ionizers
Nov 28, 2008 | ViewSonic VX710 17" Flat Panel LCD Monitor
ViewSonic VX710 17" Flat Panel LCD Monitor Logo
238 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
