Question about Acer Aspire 5100 Notebook
How can you copy audio from you tube to cd or i pod?
    Guru:
  • 177 Answers
Yes, I did that with Leawo Free YouTube Downloader.
Leawo Free YouTube Downloader is a powerful YouTube downloader that will help you easily download videos from YouTube and rip the music from the videos.
This is tutorial - http://www.leawo.com/flash/rip-music-youtube.html
Posted on Jul 27, 2010
    Guru:
  • 109 Answers
You cannot copy Audio from Youtube. But there is an alternative. First you need to install Youtube Downloader in order to download the videos or the audios from Youtube.
Next you will also need a FLV to MP3 converter in order to get the Audio which will be compatible for CD or iPod as files downloaded from Youtube will come in .flv extension which doesn't work on normal CD player or iPod.
Posted on May 31, 2010
Just descaled my 2 year old SENSEO machine. Everything working well EXCEPT only coloured water comes out into the cup. tried with several different pods.
Hello, Chris -
The problem may lie with the small tube which pokes a hole in the coffee pod. The tube may be blocked by bits of coffee grounds or loosened scale.
You will need to remove the holder into which a pod is to be inserted.
You then should be able to snap the holder apart.
Then, you should find the small tube which pokes a hole in the pod for brewing.
Use an unbent paper clip to try to gently dislodge anything that may be blocking the tube. Do this over the kitchen sink while water runs over the tube.
There are also tubes which inject water into the pod. Find them and use the paper clip to dislodge any clogs.
Reassemble the coffee maker.
Without inserting a pod, run water through the machine in the brewing cycle - 3 separate times. Place a glass or metal measuring cup to collect the water. Notice if any debris comes out with the "brewed" water.
Then, insert a pod into the machine and run the brew cycle to determine if the coffee is properly brewed.
If the coffee still isn't brewed properly, I suggest you contact Senseo (owned by Philips) Customer Service by telephone. I have no idea where you live, so I cannot provide you with the correct telephone number to call.
I am answering from the USA.
Best wishes.
Apr 19, 2018 | Coffee Makers & Espresso Machines
I have a bose radio which is 8 yrs old..what i am trying to do is connect my mini I Pod to my bose...I have audio in and outon back of my bose...I tryed a cable which just has to male ends 91.CM AUDIO...
hi,
You need a STEREO to RCA cable for connecting you I pod to the audio input of you boss. you Can connect the stereo jack in the one end of the cable to the I pod and the RCA end to the boss's audio input L/R.
i have added the picture of the cable for you reference.
ok
Apr 04, 2011 | Bose & Wave& Music System
I have a Sonic Integrity Tube Pod (Tube Pod) and need to know how to make it work with iphone 4. I can play the iphone 4 only through the earphone jack at this point. The iphone 4 however can sit on the...
It is normal to get incompatible devie message when you attach your iphone to dock because you don't use apple dock. I have 5 different brand portable speakers, charging docks. And all of them give same message when i attach my iphone 4 to dock. When you press "ok" on your iphone screen, it should start to play your songs. You don't need to use your iphone at airplane mode.
You may have problem with your iphone dock conncector cable pins. If audio related pins are damaged, you can not use any external iphone speakers with your iphone4. In order to test your sonic integrity tube pod; try another ipod or iphone on its dock. If it gives same result, you may need to change dock connector unit on sonic integrity tube pod due to damaged pins. If it works; iphone 4 dock connetor cable of your iphone 4 needs to be replaced.
Nov 29, 2010 | Sonic Integrity MP5-DS iPod Tube Docking...
How can I get my mitsubishi car cd player to play all types of cds. It only plays original cds and not copied cds.
this can not be done to the factory deck you would have to replace it if wanting to keep factory just get an aux or i pod cable intergrated with your factory deck
Aug 22, 2010 | Digital Audio (DADVDP) DVD Player with AM/...
426290 AM/FM Radio: stereo while in cd or i pod mod is going off and (...
Vibration Damage to the audio circuit, If it's an 06 or newer, contact Iron Cross Audio for repair. www.ironcrossaudio.com
May 17, 2010 | Harley Davidson 426290 AM/FM Radio
How do i hook up my i pod up to a mcm530 philips stereo system?
If it has an aux imput all you need to do is get a dock (which will keep the battery charged while playing) or the cheaper way - by connecting a 3.5mm plug to two RCA phono plugs- lead. The 3.5mm plug goes into the headphone output of the I-Pod and the RCA's go into the Aux imput of the Philips.
It can be any imput on the amp (except phono) such as CD or tape.
You will find that you need to turn up the volume on the I-Pod to hear the sound.
Mar 08, 2010 | Philips MCM530 CD Shelf System
Tuner works but when cd or i-pod are selected they indicate theyare playing but no sound.
Is your stereo sytem amplified? if so then the remote turn on wire may be hooked up to your power antenna turn on wire. The amp needs to be connected to blue w/ white strip.......not solid blue. The solid blue turns off to lower a power antenna when the tuner is not in use. Blue with white always stays on with tuner cd or ipod.
May 23, 2009 | Car Audio & Video
Trying to install i-pod adapter CD-IB100
go on crutchfield. It's called a passthrough which will allow you to have both items.
Dec 29, 2007 | Car Audio & Video
Acer Aspire 5100 Notebook Logo
98 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
