Question about GE Profile Harmony DPGT750GC Gas Dryer
The dryer turns on but is having a hard time spinning?
  • GE Master
  • 43,501 Answers
There can be many reasons why your dryerthe dryer turns on but is having a hard time - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turningDryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 08, 2010
Front load dryer wont spin with towels in it
Is the motor growling on start with nothing in it? Is the drum hard to turn? It could just be a worn out motor is all of the above suggestions are covered.
Nov 11, 2015 | Dryers
Spin dryer switch on but still hard to start otherwise if shafting is pushed clockwise it runs very slow.
Have try to turn the switch on top on the right and then hit start
Mar 10, 2015 | Dryers
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here https://www.youtube.com/watch?v=tVc6SZ2DD4U
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
Dryer will not stop spinning when door is closed
Good Morning Jeff,
I see that you are having trouble with your Frigidaire dryer, model# GLGQ2152ES, to stop spinning, even though all the lights are off. It could possibly be the different boards and sensors miscommunicating with each other. I suggest giving the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 2-3 minutes. When you turn the power back on, if the dryer is still spinning, without you wanting it to, I would suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
Mar 19, 2014 | Frigidaire GLGQ2152ES Gas Dryer
Dryer wont start, makes humming noise and thats all
sounds like you have abad motor,try spinning the drum by hand,if it moves most likely it's the motor,or the belt broke and is jammed in the motor stopping it from spinning,or if it's hard to turn something could be stuck in the blower wheel but it's the motor making the noise.you need to get in there and check it out.the motors are easy to change out on a kenmore dryer,also next time send the model number.let me know what you find
Aug 20, 2010 | Amana Dryers
My LG dryer does not spin...everything gets hot and works except either it spins VERy slowly or not at all
Open the back to get to the motor and check to see if the belt is loose on the motor pulley. Try to turn the empty drum by hand--does it seem bound up? Turn the motor pulley, does it seem hard to turn? Maybe the motor pulley is loose on the motor shaft. Run the dryer for a short time to watch the action of the drive belt.
Sep 27, 2009 | LG DLE0332 Gas Dryer
Hello,my name is David ,I have a Maytag washer maytag lsg7806aae
can you tell if the motor is turning,if so it could be your idler pulley and youve lost belt tension,otherwise it could be your motor start capacitor if motor spins freely with power and belt off
Sep 01, 2009 | Dryers
Dryer won't spin
low voltage to the motor or a bad motor
Dec 03, 2008 | Dryers
The motor on the Maytag Neptune MDE7550 Dryer is very hard to spin by hand. Is this normal.
You should not need to spin the motor by hand. Check if the belt is not to tight or the motor itself could be defective.
Apr 15, 2008 | Dryers
Wont spin or drain
The drain pump is jammed or clogged up. Remove the filter cover and check for bobby pins, coins or bra wires. If clean, remove drum to pump hose from the pump and check for any foreign matter. Try to turn the pump impeller by hand. It should turn freely. If pump is not free, replace it.
Nov 03, 2007 | Maytag Neptune MAH5500B Front Load Washer
GE Profile Harmony DPGT750GC Gas Dryer Logo
81 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
