Question about AO Smith 2 hp Swimming Pool - Jet / Well Pump Motor / Century B124
My A.O. smith pool pump doesnt seem to be getting electricity. It makes no noise at all when you turn it on. We had a storm last night I don't know if it tripped some sort of switch. I have checked the circuit breaker. My Polaris pump and blower for the hot tub is getting electricity.
  • AO Smith Master
  • 1,338 Answers
VOLT METER TO THE 2 LINES 230 OR SO ? THE MOTOR MAY BE BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY..USE YOUR ZIP CODE ... GOOD LUCK AND VOTE FOR ME...JAY
Posted on Aug 23, 2010
I have Hayward (A O Smith) 1.5 hp pool pump c48l2n134b3, was makeing loud noise, but today stopped working and is making sound like zzzzzzzzzzzzzzzz sound, but not pumping or working. Do i need a new...
sounds like a seized bearing. they can be replaced at your local motor shop or pool store. now that its buzzing, i would also suggest getting the start capacitor replaced at the same time.
Oct 05, 2013 | Hayward 1.5hp Pool Pump Motor Motor A O...
A. O. Smith 1 1/2 hp. motor Type SP. Humms then
You have a failing start/run capacitor. Take the motor to your pool supply place for repair.
Aug 03, 2010 | A.O. Smith Pool Pump Motor Square Flange...
1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
May 02, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
My new AO Smith 2HP pool pump won't pump water, just hums
I'm guessing that you replaced the motor that goes to the pump, not the pump itself. You know the motor works just fine. Is the motor rotating in the correct manner(clockwise or counterclockwise) in relation to the rotation of the pump? Have you checked the pump to see if the impeller is working/rotating? Is the motor hooked up to the pump correctly, so that the motor is turning the impeller? Are all connections to the pump tight, so there are no suction leaks? Have you primed the pump and purged it of any air locks?
Aug 11, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Pump motor making noise but not screaming. Does
Usually this is one of the bearings in the motor. I don't know of a good shop in your area. Check pricing carefully. Sometimes it is only a few dollars more to buy a brand new motor.
Jul 09, 2009 | AO Smith Pool Pump Motor 1HP Square Flange...
I have an A.O.Smith Century Pool & Spa motor 1081 pool pump duty 1.5 HP. It is making a very loud noise, do you think it needs replacement or should I look for something else?
THIS IS LIKELY CAUSED BY SOMETHING IN IMPELLER TURN OFF POWER SEE IF YOU CAN SEE ANTHING IN IT YOU HAVE TO TURN HANDEL VALVES OFF PUSH DOWN IF YOU HAVE TO OPEN PIPE IN FRONT OF PUMP I
Jun 19, 2009 | Hayward 1.5hp Pool Pump Motor Motor A O...
High Ringing Noise
Sounds like it just needs lubricating. It's probably dry seals rubbing against the stainless shaft.
Bad bearings usually make grinding noises. Replacing bearings can be a DIY job, but not a teriffically simple one.
Apr 21, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
AO Smith 2 hp Swimming Pool - Jet / Well Pump Motor  / Century B124 Logo
141 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
