Question about Kenmore 24032\24036 Top Load Washer
What size tub is my kenmore washer model 11022722100
  • 15,935 Answers
3.6cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Kenmore washer model 11022722100 wont spin out wet clothes
the PCB has a problem and only a certified tech should try repairs
Sep 13, 2017 | Washing Machines
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Speed knob and stem broken from Kenmore washer Model #11022722100. What parts do I need and how do I replace parts on washer.
While the speed knob and dial are relatively inexpensive, the "stem" you refer to is actually the washer Timer which sells for between $100.00 and $150.00. You can find appliance repair parts at http://www.partstore.com/
May 23, 2009 | Kenmore 22422 Top Load Washer
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
I have a Kenmore washer model 417.44072300. I
3.4 cu ft.
Mar 27, 2009 | Kenmore Washing Machines
Washer won't drain
The symptoms you describe are typical of a lid switch failure. When a lid switch fails, the washer will fill, but stop at the spin cycle and will not drain. Sometimes it will fill, then stop. The switch is located under the washer top cabinet on the right hand side and is activated by a small plastic piece on the lid (called a "lid strike") through an opening along the right hand side of the casing next to the wash tub opening. First, make sure the lid strike is still intact on the lid. Next, open and close the lid and listen for a "clicking" sound. This is an indication that the lid strike is at least making contact with the switch. Then, check the two screws along the right side of the wash tub opening that hold the lid switch in place. Sometimes the screws come loose or fall out causing the switch to fail to contact the lid strike. In many cases, all that is required is to tighten these screws to realign the switch with the lid strike. If all these preliminary checks fail, the lid switch should eb replaced. The following link explains how:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you require parts, go to searspartsdirect.com and type in the model number you provided. The lid switch will be listed under the "Top and Cabinet" heading as item number 11. The lid strike is listed as item number 20.
Some other sites to view are repairclinic.com and appliancepartspros.com. Sometimes these sites offer better pricing on parts.
If you have questions, or if the diagnosis is incorrect, please post back and let me know. I hope this helps you.
NOTE: If the wash tub is full, you DO NOT have to empty to complete this repair. Once a defective switch is replaced, the washer will spin out and drain on its own.
Jan 23, 2009 | Kenmore 24032\24036 Top Load Washer
Cold water leaking in washer tub
Replace your fill valve and you will be back in business.
May 27, 2008 | Washing Machines
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
435 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
