Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
Intermittent leaking during wash cycle
I use the regular cycle or the quick wash and every once in a while the dishwasher will leak out about 1/2 a gallon of water onto the floor. It does not happen every time. When I took off the lower cover and looked at the hose attachment there is no signs of leakage from the connection. Should I take off the front panel and check for leaks? Could it be originating from under the dishwasher because a drain is blocked? Please let me know what I should check next - thank you.
  • 523 Answers
Is the dishwasher leaning foward,are you useing to much soap?start the dw with out anything in it let it run a few minutes open the door and see if there are suds in it if so way to much detergant
Posted on Jun 01, 2010
Hobart lx30h leaking from bottom
This is a testing for the post on this web site, not a solution.
Mar 27, 2014 | Hobart Lx30h Commercial Dishwasher
Some water is leaking under the dishwasher and on the kitchen floor during the end of the wash cycle.
Does it leak during pump-out only?
If so , must be drain hose .To see everything,remove kick plate to isolate leak. Check hose connections. Fill and drain and observe.Or run a whole cycle with kick plate off to find leak.
Good luck
Aug 15, 2011 | Kenmore 24 in. 15689 Built-in Dishwasher
My dishwasher (model # DU81ODWGU1) is leaking water and suds during the wash cycle. I ran out of dishwasher powder so I had used regular dish soap for this cycle. Did this cause the problem? My...
MOST DEFINITLY You can put regular dish washing liquid in a dishwasher will do that every time take a few washings to stop run 2-3 times empty it will stop.
May 06, 2011 | Whirlpool Dishwashers
High oitch noise during wash
As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
May 04, 2010 | Frigidaire Professional Series 24 in....
Indesit IDL 500 Pump noise when switched on not continuous, sounds like it is acting in surges, and the pre-wash indicator light flashes in time with the surges. Is this a fault, what is the solution?
this indicates that there is water in the base of the unit activating the safety float switch... usually a leak..or an overfill due to blocked filter
Power off & remove plug
1st port of call would be to drain the base by pulling forward and tipping back.. make sure you have large towels to hand...
Once drained power up again and put on quick wash...
if cycle completes verify no leak by tipping back again and no water should flow..
if there is a leak then the flashing would resume during cycle... and best get someone in to locate as there are a few possibilities...
Dec 18, 2009 | Indesit Dishwashers
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
118 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
