Question about Dell 725 InkJet Printer
Dell 725 wont work
I moved my computer to a different room in my house so i had to unhook everything and when i hooked everything back up my printer wouldn't work
    Sergeant:
  • 202 Answers
Hi aliciaa
I think you just need the installation or setup instructions for your printer. I suspect something is simply unplugged or similar.
HERE you will find Dell's manual for their Photo AIO (All In One) 725 personal inkjet printer.
HERE you will find Dell's page for trouble-shooting problems related to your printer.
HERE you will find all the drivers and downloads related to your printer on Dell's web site.
Make sure that there is a cable going from your printer and plugged into your computer. Make sure the cable is fully "seated" (plugged in completely) on both ends (at the printer and at the computer.)
One other cable should be coming from the printer. That cable will be A/C power cable. Make sure it, too, is seated properly (fully plugged in) at the printer and at the A/C outlet you are using for it.
If the power cord is in two parts (one w/ a "block" on it), make sure that the two segments are joined together completely. The segment of cord w/out the block on it will plug into the "block". Make sure it is seated in properly as well.)
Finally, make sure that the outlet that you have the printer plugged into is working. (Plug a lamp or something similar into that same outlet and confirm that you are able to turn on the lamp.)
Please, let me know if this response was a "FixYa"
or "Helpful" for you or, of course, if you have
any additional questions, etc on this topic.
If the information I provided you w/ resolved your
problem or lead you to a resolution for your
problem or an answer to your question, then, a
"FixYa" rating would be most appreciated. @:)
It is best to wait until the problem has been
resolved b4 scoring the experts who participated in
solving your problem or answering your question.
(Once you enter a rating, the problem will be
closed and we will not be able to continue to assist
you.)
Very often it will take more than one exchange of
information between you and an expert in order to
resolve your problem. If a proposed solution
doesn't work for you, don't rate it yet. Instead,
post back here letting us know and we'll continue to
work w/ you until we find a solution that does work
for you.
Thank you
BJ @:)
Posted on Apr 08, 2008
  • Anonymous Apr 17, 2008
    Hello Alicia,
    How did it go? Did the information and links I provided you w/ enable you to get your printer set up and working OK in its new location?
    I DO hope that is the case. :) If it isn't, please, post back here and we'll continue to work w/ you.
    If it is the case, would you kindly take just a moment to close the problem by assigning a FIXYA rating for my "solution"? I would be very grateful for your generosity and show of appreciation.
    Thank you once again for using FixYa! Have a beautiful day.
    BJ @:)
SOURCE:
I change the ink jet on my dell 725 printer, and the printing is so faint.
Are you using Dell Series 6 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. This will reset any error messages the printer has.
Plug everything back in and power on the printer. Now remove the Dell Series 6 Color cartridge. Make sure the tape is off the cartridge and reseat the cartridge. Then close the printer and it will print an alignment page. Any error messages?
Dell Series 6 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges
Dell Series 6 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It is possible the cartridge has a bad sensor. Try taking it back to the place of purchase for a replacement.
Rick
May 14, 2011 | Dell 725 InkJet Printer
My printer which is a dell 968 is hooked up to my dell computer and was working fine for awhile. Then all of a sudden it wont print antything. We even bought a new usb Cable...unhooked it and hooked it up...
Yes it does sound like a computer problem, your usb controllers are malfunctioning. Try reinstalling your motherboard chipset driver and see if it resolves the issue. And let me know if u need more help.
Jun 26, 2010 | Dell 968 All-In-One Printer
Dell 725 printer wont print after windows 7 install
You need the correct drivers for the printer. Go to Dell's support page and download and install the Windows 7 driver.
May 27, 2010 | Dell 725 InkJet Printer
I dont know where the Dell 725 Printer Power Cord goes into the tower Which outlet on the tower
The Dell 725 printer power cord does NOT plug in to the tower. The Video Cable, on the other hand, plugs in to the tower's video output. Look for a connector like the one from the printer (often USB these days) to plug it in to the computer. There was a diagram that came with the computer that showed how to do all the connections, and the Power Cord does NOT plug in to the tower. USB connections are in various locations on your computer's tower, in the back and sometimes in the front too.
Nov 09, 2009 | Dell 725 InkJet Printer
I can't print, everything is hooked up but when I go into my computer & look at printer it says offline.
When you hooked it up, did you install the drivers BEFORE connecting it? That's a key difference these days, and can cause communication failure. I'd suggest backing up, unhook the device, uninstalling the drivers, reboot, reinstall the drivers and THEN hook up the device.
Oct 22, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Scanner
Most lexmark all in one printers require that the drivers be installed first before plugging it into the USB port. If you were moving it, their could have been a chance it didn't get placed back into the same port it was before the move. To solve this issue, either plug the printer into a different USB port or reinstall the printer. I would try option A first, you will know when its correct when A it prints and B you dont recieve a notice on the screen for a driver request.
Feb 23, 2009 | Lexmark X4270 All-In-One InkJet Printer
Problems with setting up wireless router wrt310n, wireless printer Dell 968W, Dell XPS laptop and Hughes net
Try reseting the wireless router, theres a reset button hold it down for 30 seconds.
Oct 05, 2008 | Computers & Internet
Ghosts on my tv
if you can, try hooking up the tv to a different cable line in the house or bring a different tv into the room where the bad picture is [ you may have a bad connection or wire ] if this doesn't help, try rabbit ear antennas just to get a picture. if you still have ghosts on your tv, the problem is with your tv.if the picture is fine, there maybe a problem with your cable service.
hope this helps
wg
Feb 10, 2008 | JVC AV-56WP74 56" Rear Projection...
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
Problem with Dell 725 Printer
We have the same problem. It seems to help if you load a lot of paper
Oct 07, 2007 | Dell 725 InkJet Printer
Dell 725 InkJet Printer Logo
229 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
