Question about AOC CRT Monitor
Computer I over clocked my CPU and now the monitor wont start
    Guru:
  • 1,342 Answers
What did you over clock in particular? If you can get in via safe mode try lowering the refresh rate for your monitor.
Posted on Apr 09, 2008
SOURCE:
My monitor wont turn on but the cpu is running
Please check with another monitor and make sure computer is working fine. Since CPU is running it may not be the issue with computer. After check with another monitor please contact your technician.
Jun 15, 2010 | AOC 7 F-SLK 17" CRT Monitor
Hp l1906 LCD MONITOR SCREEN WONT DISPLAY. power lcd green light keep blinking. Any solution? thx
It is possible that the video card in cpu is bad, try hooking up another monitor to the cpu (computer) if you have one that will let you know if it is the monitor or the computer video card, Could be as simple as the driver is missing.
Feb 01, 2010 | HP L1906 19" LCD Monitor
I do not understand why my computer monitor keeps turning off...
Possible overheating problem caused by:
1 Fan motor inoperative - replace
2 Components are caked with dust/dirty - Clean with compressed air and re-assemble.
3 Over clocking the CPU; running system faster than you're supposed to.
Hope any of this helps,
JZ...
Nov 25, 2009 | HP Computers & Internet
Green light is not on in front of CPU. Monitor shows nothing!
ok memeory problem
try another chip and see..
Nov 14, 2009 | Intel Motherboard
Nvidia gedorce 8500 gt and the cpu gets overheated and shuts down
well it might be over clocked, but i have a computer with 4 fans and cpu fan and other fans to. though this still doesnt make a difference casue my cpu still heats up. so get a liquid cooling system, expensive i knw but it will keep your computer running, but you coudl also try cleaning you computer out. Like all of the dust and everything
Apr 26, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
No display
it may be the problem of your monitor.check it
Jan 11, 2009 | Intel Motherboard
No image input and pc makes weird sounds on start up
Remove & reinstall all the memory sticks (reseat). If that did not fix the problem, remove all the memory sticks and reinstall them one at a time to test them in an effort to determine if one of them has gone bad. Use this same methodology to test all of your device cards.
Check to make sure the CPU fan wire is connected to the fan header on the motherboard and that the fan is operational. Most motherboards (especially AMD) require the CPU fan to be operational and connected to the motherboard to avoid frying the CPU. However, this requirement can be disabled in the bios to accomodate CPU fans that do not run off of the motherboard fan header.
Can you get into the bios? If so, I would suspect the CPU and memory are ok. Does the clock have the right time? If the time on the clock is wrong it could indicate your bios settings are not being maintained after you power down and you may need a new CMOS battery.
Usually a beeping motherboard is an indication of a hardware issue. The data on your hard drive is probably intact. If you need to retrieve some files from the drive for your graduation, you can always install the hard drive into a USB external hard drive enclosure and connect it to an oprational computer.
Hope this helps - good luck!
Nov 01, 2008 | Computers & Internet
Help my computer wont start if I close my lid ....
It sounds to me that there might be a lose connection somewhere. The first thing to do is make sure that all cables are securely fastened.
When you say that your computer won't start when you put the cover back on and lay it on it's side does it respond at all when you hit the power button? Lights, anything displayed on the monitor, fan noise, etc.? Also when you leave the cover off is the computer laid on it's side like when the cover is on? does it work laying on it's side with the cover off?
MO
Jul 13, 2008 | Acer Veriton 3600GT PC Desktop
No signal on first boot
This would usually indicate that there is a problem that is causing your computer to not boot correctly all of the time. What you have described could be many different problems and without more information I cannot say which one it is.
1. Hard drive. I have ran into Hard Drives that for some reason do not start up correctly right away when you put power to them. This can cause the initial startup to hang possibly indefinitely.
2. Video Card. Something probably firmware is causing your video card to not start up properly when power is first applied.
3. PSU. The power supply could cause similar problems if it cannot supply enough power because the highest power draw is when you first turn on the computer. When you push the reset button the power is already being supplied to most of the components and the ones that did not have enough power to start properly before can do so now.
4. CPU. If the CPU has some minor problems it can cause similar problems. In any case to fix it you can try clocking down the CPU but you are better off replacing it.
5. RAM. I have had similar problems with RAM. Clocking down the RAM fixed the issue.
6. Settings in BIOS. I would check to make sure the setting for init display on boot is set for PCI-e.
Nov 06, 2007 | XFX GeForce 6200 Graphic Card
Computers & Internet Logo
Top AOC Computers & Internet Experts
Ekse
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
