RCA F27442 27" TV Logo
Anonymous Posted on May 31, 2010
How do i reset this tv?
I got it from a hotel that was closing i i think they deleted some channels .
Anonymous
Level 2:
Novelist:
  • Expert 144 Answers
  • Posted on May 31, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
144
Questions
0
Helped
40597
Points
417
The TV will search for active channels and add them itself. Use the remote to select the on screen menu and go to the Channel Setup mode. Then just push the up arrow and it will add the channels for you automatically.
There is a possibility that this set has another "mode' where you can select "hotel" or "standard" if it's there make sure you set that to standard the "hotel" mode disables some of the features like the ability to set the channels. I can't find this owners manual on line for free (RCA usually won't provide them) I can't be more specific. I doubt that you got a copy of the owners manual when you got the TV.
Zashiban
Testimonial: "thanks ill try a hard reset, see if it works"
2answers
LG 37LG500H remove Hotel mode.
go into tv set up and turn off hotel and turn on home
1helpful
I have a LG 32ld333h tv it won't auto tune and doesn't have a add/delete how do i get it to program channels
You sir have a hospitality tv used only in hotels and motels proidium tv type that needs a master remote or call best buy to reset to consumer type tv from commer
13helpful
2answers
I have Onida TV Model 21 inch , I accidentally enable the features of volume lock, hotel mode and channel lock and I cannot reset the same. Due to this, I cannot increase volume of telivision
MIGHT WORK IF YOU:
Turn off tv with remote, that is standby, then turn off tv with switch or unplug from wall. Wait a few minutes until led lights go off on tv. plug tv back in. try pushing vt on remote and power button on tv at same time.
If this doesn't work try contacting a local retailer, they always have a list of codes for their salesmen.
The tv I purchased is from a hotel, and hotel have tv's that only play setain channels. is there a way I can reset the tv to pick up all the prime basic channels?. Hope you can help.
It may be a monitor only with no tuner section of it's own or a customised tuner for receiving a house channelling system, like a company Intranet.
If it has any analogue or even digital inputs, however it was connected in the hotel, you can plug in a DTV decoder box, or satellite dish box etc and get full range of programmes available where you are.
1helpful
Hi, I just bought an older model Philips Magnavox from a hotel(Model Number: TL7127C107 Chassis Number: 27B700-7562). The T.V. itself works fine but I can't access all my channels. I did a little research...
sorry, it wont go away, bet ya got it cheap huh(nothing intended by cheap) but the tv hotel mode is telling you that its a special tuner made for just hotels, the only way to get around this is if you can replace the hotel type tuner on the main-board with a normal type tuner, it'll cost more than you paid though.good luck,a friend of mine bought 12 of then at $25 each, boy he thought what a deal, now he's really crying and they didn't tell him,and they won't refund his money
Hotel TV
check in preset under menu the channels 30 above maybe skip, set this channels to skip off. or just do the auto tuning.
1helpful
I cannot reset the channels on my TV. It is the Concierge TV from a hotel. Will I need to buy a Zenith Remote from the store to do the channel programming. It says it is locked
You have a hotel/motel model that cannot be programmed or any of the settings changed without a special Master remote. Sorry, doubt that you can buy one from the store, they are not sold to the public. Contact the hotel where you bought the set and try to get the model number for the remote from them. This is a different number than the model number of your tv.
Hotel on
What do you mean you activate (hotel on)? Try you use remote control set it in company settings or you reset your tv.
2answers
Locked out TV channels
Need a make and model to determine what codes needed to unlock.
1helpful
2answers
Trying to get channels above 42 to 99
I had the same problem the solution is you have to get institutional remote and reset the tv from commercial mode to consumer mode and then you will have access to the full menu. go to www.phillipsitv.com to get the directions. I actually asked a Hotel could I borrow their master remote used it and took it back and my tv works fine. Hope this helps.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
