Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Flow indicator not spining
Flow indicator not spinning. any ideas ?
Yes I also had this problem after just one use. There's several things that you should check. 1. pull side panel off where the belt is located and see if the liquid in the clear tubbing is flowing.I there is a bubble in the line the pump has lost it's prime and needs to be turned off for a minute then restarted. 2. make sure the belt is not broken this drives the solution pump and well as the cleaning wheel. 3. the lines that the solution flow though are clogged. always rinse the machine with water when done cleaning. Good luck.
Posted on Jun 02, 2010
Bissell proheat cleanshot 2x won't stop putting out cleaner and water, the little dial won't stop spinning
First clean the Flow Indicator filter. Turn the Flow indicator cap counter-clockwise to remove it. Lift the rotor and the filter under it out. Clean the filter and reinstall in reverse order. Make sure you have unplugged the unit before working on it. Then clean the lint filter on the heat tank cap (it looks like a screen) and reinstall it. There's not much more to these so if that doesn't work call the Bissell Consumer Care at 1-800-237-7691
Oct 11, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat flow indicator wont spin
Hey Traci! You may want to have one of BISSELL's Authorized Service Centers inspect your machine.
Here's a quick link to assist you in locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Feb 11, 2013 | Bissell Vacuums
Hi. Would you know why the flow indicator on my Bissell Proheat won't spin.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
trwwt
Mar 13, 2010 | Bissell 1699 ProHeat Clear View Upright...
Vacuum billows dust
Its clogged. It needs to have a thorough clean out and this can be done by removing the sole plate / floor head where the beater bar is and checking to see that all the air ways or the dust channel that flows through t he main spine neck at the back is clear, checking the main spine at the back is clear and finally to check that there is no clogging at the top of the back spine as well. Oreck XL can become clogged quite quickly due to its relatively small suction tube openings and small motor.
Nov 13, 2008 | Oreck XL2200 Bagged Upright Vacuum
Air flow indicator stays activated after filter has been cleaned. Brush spins, but very little suction. Dirt doesn't spin in cup.
Your vacuum is clogged. Check all of the air pathways, hoses, etc. The most common places to check are anywhere there's a joint in the airways, and also directly behind the brushroll.
-R
Aug 12, 2008 | Hoover U5507900 Elite Rewind Bagless...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
821 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
