Question about AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
Motor is very noisy - AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
  • Steve Jul 08, 2010
    This may be a bearing issue. Check out this AO Smith Pump Motor troubleshooting guide, at the link
    below:http://www.aosmithmotors.com/WorkArea/Do... Please
    rate this reply if helpful - good luck!
Noisy motor indicates bearings on the shaft are going bad. This happens when you have a shaft seal leak and the leaking water is getting to the bearings. Sounds like you need to replace shaft seal and set of shaft bearings. Easy fix is to replace the motor only for about $150.00 for motor replacement. Around $40.00 for seal and bearings and some of your time.
Posted on Sep 13, 2010
Fan blower motor noisy. Now motor will not run has whinning noisy
Motor is seized but power is trying to turn motor and that is what causing winning noise
Apr 11, 2016 | Cars & Trucks
How to fix a noisy evaporator fan in a frost free refrigerator
The ice usually makes a fan noisy by filling the cavity it needs to move the blades in. check if this is the case, if there is no obstruction and the fan motor itself is noisy it needs to be replaced or serviced, servicing parts is trickier to find than the little motor it self.
To clear the ice just let the fridge stand for a few hours and to help the process speed up you can spray the evaporator with luke warm water.
Feb 26, 2015 | Frigidaire Refrigerators
Noisy motor
If it's noisy like a tractor it might be an exhaust leak. If it sounds like a ticking it's probably a noisy lifter.
Apr 21, 2014 | 1994 Pontiac Bonneville
Flotec pump 1hp motor has become too noisy when running
Is it the pump or motor. Pumps do wear out and need rebuilding or replacement.
Dec 17, 2013 | Plumbing
Simpson 175 washing machine: spin cycle noisy and motor cuts out after short spin. Bowl feels stiff
Hi just read your posting.Now from the information on your posting the machine is noisy on spin and your motor is cutting out after a short spin.Is this correct?Now does the motor cut out during a wash cycle?If the motor only cuts out during the spin cycle , and with your machine being noisy on spin,I think the fault will be your bearings are corroded.With the bearings being corroded it puts more load on the motor causing the inbuilt thermal overload in the motor to activate and turning the motor off to save it from burning out.Please reply with additional information on, if it cuts out on wash and I am sure I can help you further.
Aug 07, 2010 | Washing Machines
Numatic gve370 canister wet/dry motor gone noisy
Try blowing out the motor housing with commpressed air through the cooling vents as it is running, if that dont quiet it down it may be the bearings are dry and need to be oiled, use 20w 3 in 1 oil in the blue container.
Nov 11, 2009 | Numatic GVE370 Canister Wet/Dry Vacuum
Noisy motor
the best thing is to get a new motor from hotpoint website hope this helped
Mar 23, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Dryer guide wheel was noisy and I opened the dryer up and found the wheel and stud badly scored. Fixed that and put machine back together and now the motor is very noisy and the machine shuts off...
you need to check the blower fan. the motor has a "D" shaped shaft. over time the blower wears, the motor will spin but the blower does not. the air flow stops and the drier over heats. replace the blower and it should be fine.
Nov 08, 2008 | Dryers
Dishwasher motor is more noisy than it used to be.
Mine does the same thing all kinds of different sounds. This is the 2nd replacement
Jun 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90 Logo
503 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Larry Maranto
john h
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
