Question about HP Color Laserjet 3550 Printer
Color LaserJet 3550 Error
Hello Guru.
The above Printer is on a Network shared by 8 Users. Only one User is having a problem i.e. when she prints 7 out of 10 pages results in caracters or gebberish.
I have completly deleted the drivers, reboot and installed fresh drivers from HP. Still not working. Her PC.. Win2K SP4, everything was fine till two weeks ago, and this Printer has been in operation for two years, no any other problems.
So, I think it might have something to do with the User's PC, but what will that be? Definitly, not the Services nor Print Spooler which I've Stopped and restarted once.
Help.
  • 1 more comment
  • odms3 Apr 09, 2008
    Yes, I did re-installed fresh drivers from HP. Even installed WinXP Drivers, today I rolled back the XP driver and back to Win2K Drivers, still.
    I just found out that those documents I have been printing were created as PDF with "CuteWriter." I am begining to think that is the source of the problem. 'cos I am able to print muitiple documents from Word, without a problem.
    So, that gives me something to think about knowing that it's not the Printer.
  • Dave MacPhee
    Dave MacPhee May 11, 2010
    Also, did you download the latest driver?
  • Dave MacPhee
    I would say almost for sure that the PC is the problem and not the printer...
    2 weeks ago... Was there any new software or windows updates installed? Sounds like something has changed on her PC that has done something...
  • 236 Answers
My solution then, is do not use CuteWriter as it sounds like it is causing a problem..
Have you tried this program/pdf on another computer? Does it have the same error?
Posted on Apr 09, 2008
  • Dave MacPhee
    Dave MacPhee Apr 09, 2008
    If the error occurs on another computer as well, there is your problem.. If it does not, perhaps there is a software issue with Windows 2K SP4. Maybe try updating CuteWriter to the latest version, and make sure it is compatible with SP4
  • Dave MacPhee
    Dave MacPhee Apr 11, 2008
    what version of CutePDF are you currently using?
How do I fix error 571 on my 9800 monarch ticket machine using my loftware 32 design ticket?
If you are getting error 571 from Nebraska Book Company's WinPrism inventory control system, File --> System Settings --> set the Receipt Type to 8-1/2 X 11. It seems irrelevant but it works.
Another possible resolution to the problem is to remove the Windows (XP, 7, 8, 10) profile of the offending user:
0. Login as the offending user and backup anything they want to keep, like browser bookmarks/favorite or documents on the desktop.
1. Log into Windows as a local administrator.
2. Control Panel --> User Accounts --> select the offending user --> Remove.
3. Restart.
4. Log into Windows as a local administrator.
5. Delete C:\Users\offending_user
6. The following is necessary to avoid a "temporary profile" error: Regedit.exe HKEY_LOCAL_MACHINE --> Software --> Microsoft --> Windows NT --> Current Version --> ProfileList --> select each entry until you find the one with a ProfileImagePath of C:\Users\offending_user and delete it.
7. Control Panel --> User Accounts --> add the user.
8. Login as the offending user, add the printer, and now it should work.
Jun 15, 2012 | Office Equipment & Supplies
How to add NIC in HP color laserjet CP1215 Printer?
If this model HP does not have an expansion slot for a HP Jetdirect Print server, then to use this printer on your network you have two options.
1. Connect the printer to a desktop computer on your network and set it uo as a shared printer. This means this computer and printer needs to be powered up for the other computer on your network to print to the shared printer.
2. Connect the printer to a print server that is connected to your network.
Nov 24, 2010 | HP LaserJet P2015 Printer
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
My HP Color Laserjet 3550 Printer wont print black when it is out of color ink
go through the menu on the printer ,there is a setting where it can be set to continue printing when the toner is out.
Mar 19, 2010 | HP Color Laserjet 3550 Printer
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Laserjet 1022 not printing on shared computers
on printer properties try to set on sharing tab check marks on : share this printer- render print jobs on client computers- list in the directory ..( all of this must be chacked).. on port tab see on what port is printer ..(tcp/ip - or virtual), on advance tab.. check alway available, spool print documents first., under security see if you have set group permission.. if you did not ,, add the computers to use this printer ( in most cases this is the problem).... if all of the above s set , and you can still not able to print .. enter in run...services.msc... find print spooler and restart it .. then try to print.
Dec 02, 2009 | HP LaserJet 1022 Printer
Installing hp 3550 printer driver on new OSX leopard system
When I try to print from an access data base to the laserjet color 3500 usb printer.
Tried diff. drivers, diff usb cable, it works for a while but after several test runs the error reapears.
PCL XL error
Subsystem: KERNEL
Error: ColorSpaceMismatch
Operator: VendorUnique
Position: 9
Mar 09, 2008 | HP Color LaserJet 3500 Printer
HP Laserjet 1320 Printer
Hello
Please note: Instructions only applicable to the network printer which supports telnet protocol.
HP Mono and Color LaserJet Network Printers - Sleep Mode Problem
Issue
Network printers may not print when a job is sent to the printer while in sleep mode.
Solution
Please follow the steps below-
1. Connect the printer to telnet- Using command prompt.
2. Type telnet > IP address press then enter.
3. Type menu and press enter.
Following screen will appear-
4. Choose option 2 TCP/IP menu and press enter,
5. Choose option 5 TCP/IP other settings and press enter.
6. Type y in front of cursor and carry on pressing enter until you reach “SLP keep alive”. By default this value may be 0.
7. Change this value to 1.
8. Exit and save settings.
- Nikhil
Mar 04, 2008 | HP LaserJet 1320 Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
63 people viewed this question
Ben Johnson
