Toshiba Satellite M35x-S1142 Turn off problem
My laptop has a slightly different shutdown problem than the others I've read. It starts to boot up, the "Windows starting" blue screen/message appears and even sometimes my Windows wallpaper appears. Then suddenly, the laptop turns off. Instantly. I've suspected a power issue but I can boot into SAFE boot mode and the laptop works fine. This leads me to believe its not a power problem. What about a memory problem?
I've reloaded the HD using the restore disk and I have the same issue. Doesn't appear to be a heating issue. Battery charges fine and I have the same results with or without battery or AC power.
  • Lfamily Apr 08, 2008
    Nothing new was loaded. I tried the boot with 'last good configuration' and that didn't help. I have done a complete restore with the Toshiba CD and still have the problem. That's why I'm leaning toward a hardware problem vice software. I had this problem about a year ago and the restore CD fixed it. Appreciate the suggestions...please keep them coming.
    Guru:
  • 1,342 Answers
Seems to be a common issue with this laptop.
Look Here
Posted on Apr 08, 2008
    Scholar:
  • 67 Answers
Was something new installed. It's failing during the driver load. You can quick fix it, maybe, by booting and pressing the F8 key, then selecting Last Good Configuration (words of that effect). If that does not work, boot with F8 and trace each driver as it loads. The one it stops on is the one you want to deal with. Boot in Safe Mode again and try to fix the problem. Do you have anything showing up under the Question Mark in device drivers? You may need to deal with the problem on that level also. Cheers.
SOURCE:
Toshiba Satellite M35X-S1142 dvd rom
if you want to remove it from the laptop there will be a screw or screws on the bottom of the laptop on or under one of the covers.it will be about 4 inches in from the edge of the dvd drive.
Oct 15, 2012 | Toshiba Satellite M35X-S1142 Notebook
Toshiba doesn't have bios updates atleast not for this model
The m35 is discontinued for some time now and won't be getting any updates. If your laptop is not working well, experiences random freezeups and shutdowns, and you can't boot it properly take a look at this Toshiba m35 motherboard repair manual. This is by far one of the most common problems with the m35 and if this is the case with your laptop, a bios update won't help.
Feb 07, 2011 | Toshiba Satellite M35X-S1142 Notebook
I downloaded a movie with my toshiba laptop, in the morning I saw message that movie was ready for viewing, clicke on play and anti virus alert opened up, clicked on antivirus and screen got stuck, had to...
Remove batter, unplug adapter, hold the on/off switch in for about 20 30 seconds. re-install battery and plug in and try to turn on, see if it comes on. good luck
Nov 07, 2017 | Toshiba Satellite M35X-S1142 Notebook
I want a 3g modem to use bsnl subscription , which is best modem for me with price
All i know is that Verizon is able to provide you a good signal but i don't have any idea about the price.
Apr 24, 2010 | Toshiba Satellite M35X-S1142 Notebook
Toshiba m35x-s349 turns on but does not boot
check battery power. Lots of times laptops won't boot if the battery has gone down to low. Probably has just enough charge to turn the machine on but not enough charge to boot the machine.
Nov 09, 2009 | Toshiba Satellite M35X-S349 Notebook
Satellite m35x-s309
This can be a few things. first try and cold start it.
1. Take out the battery leave it pluged in. hold the power button for 5 sec. then release. turn on system normaly once in windows shut down. replace battery. turn back on. that should work.
2. You have a bad driver problem trying loading into safe mode hit F12 and select safe mode if it loads with no problem then it could very well be a driver or software problem
3 if nether of them work then you have a hardware problem which could be causing overheating.or just a device going bad.
Jun 29, 2009 | Toshiba Satellite M35X-S309: M35X-S309...
Dvd/cd rom
Hi!
The yellow exclamation icon means that there is a problem with the DVD driver.
Try Uninstalling the driver and let windows to recognize it again and install.
Jan 20, 2009 | Toshiba Satellite M35X-S1142 Notebook
Open Questions:
BROTHER Printer tEcH SupPoRt pHoNe nUmBeR :~{-l^8OO8O3^lO69}*-} USA vary BROTHER Printer tech Support Number +1{8OO8O3lO69}}USA Login Repair service center to resolve all BROTHER Printer customer service phone Number products.BROTHER Printer ROUTER is an American multinational company which was founded by Michael BROTHER Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, BROTHER Printer ROUTER support number, and selling of computer-related services and products. BROTHER Printer ROUTER Tech Support Phone Number Recently, BROTHER Printer ROUTER has been named the number BROTHER Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, BROTHER Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a BROTHER Printer ROUTER Service Tag or a BROTHER Printer ROUTER Get BROTHER Printer ROUTER Technical Support Phone Number and Customer Services. BROTHER Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 22, 2019 | Brother Computers & Internet
CANON Printer tEcH SupPoRt pHoNe nUmBeR :~{-l^8OO8O3^lO69}*-} USA vary CANON Printer tech Support Number +1{8OO8O3lO69}}USA Login Repair service center to resolve all CANON Printer customer service phone Number products.CANON Printer ROUTER is an American multinational company which was founded by Michael CANON Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, CANON Printer ROUTER support number, and selling of computer-related services and products. CANON Printer ROUTER Tech Support Phone Number Recently, CANON Printer ROUTER has been named the number CANON Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, CANON Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a CANON Printer ROUTER Service Tag or a CANON Printer ROUTER Get CANON Printer ROUTER Technical Support Phone Number and Customer Services. CANON Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 22, 2019 | Canon Computers & Internet
Computers & Internet Logo
211 people viewed this question
Ekse
Marvin
Marvin
