Question about Samsung SyncMaster 204BW LCD Monitor
Samsung syncmaster 204bw will not turn on - Samsung SyncMaster 204BW LCD Monitor
  • 11,361 Answers
Check the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 31, 2010
5 Suggested Answers
  • 1684 Answers
SOURCE: i have samsung syncmaster 204BE monitor. always
If you are talking about the power light flashing and no picture then its not in sleep mode, the power supply has failed. Check our web site at: HTML clipboard www.ccl-la.com Look in the monitor repair pages. We have a step by step repair guide for this model Samsung. If you don't want to do the repair yourself we do offer a repair service, information is available on our site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Dec 31, 2009
budmrtn
  • 11361 Answers
SOURCE: The monitor powers up and the analog icon blinks
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Posted on Mar 29, 2010
budmrtn
  • 11361 Answers
SOURCE: Describe your samsung syncmaster 204bw Problem: I
Check the power supply DC filter cpas first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 08, 2010
budmrtn
  • 11361 Answers
SOURCE: My samsung syncmaster 204bw power
Does it do the same with another PC?
If it is monitor, then please read below
Look for bad caps first:
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 29, 2010
Samsung Syncmaster 204bw has a red screen
A red or pink tint to the screen indicates that the back light bulbs are failing and are about to burn out. Its time to look for a new monitor.
Mar 17, 2012 | Samsung SyncMaster 204BW LCD Monitor
My 204bw says check signal and is hooked up! How can I reset it? Thanks
Make sure you have in on the right input mode.If you are not recieving anythingat all,then you could have a bad AD board, or bad inverter.
Jun 03, 2011 | Samsung SyncMaster 204BW LCD Monitor
I have a samsung syncmaster 204bw and sometimes the monitor flashes black for a couple seconds and then comes back on. it will do it and then wont for awhile.
This is an early warning that the inverter board is failing, "powers the back lights behind the screen" eventually it will go. The board must be replaced or repaired.
Feb 07, 2011 | Samsung SyncMaster 204BW LCD Monitor
I have a Samsung SyncMaster 204BW monitor using with a Dell Precision M70 latop. How can I get the monitor to display in the wide screen format (full screen)? Currently I have an almost square active...
Did you set the PC to send the vidoe signal to be at the
Native resolution of this monitor?
1680 x 1050 @60Hz.
Here is the user manual:
http://static.highspeedbackbone.net/pdf/Samsung-204BW-UserManual.pdf
Please leave rating if it helps.
http://www.fixya.com/support/r7406380-tv_training_manuals
Jan 14, 2011 | Samsung SyncMaster 204BW LCD Monitor
My syncmaster 204 bw power button is flahing blue
Your inverter board is faulty. Repair and it might work.
Jan 03, 2011 | Samsung SyncMaster 204BW LCD Monitor
Describe your samsung syncmaster 204bw Problem: I turn the monitor on, the power button turns blue, the screen remains dark, the image on my Powerbook G4 appears flashes on the screen before it goes black...
Nov 08, 2010 | Samsung SyncMaster 204BW LCD Monitor
The monitor powers up and the analog icon blinks on and off and nothing else happens...no colors...when connected to computer.. The images show for a few seconds and goes blank...turn monitor off and on...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 15, 2010 | Samsung SyncMaster 204BW LCD Monitor
The monitor powers up and the analog icon blinks on and off and nothing else happens...no colors...when connected to computer.. the images show for a few seconds and goes blank...turn monitor off and on...
Mar 29, 2010 | Samsung SyncMaster 204BW LCD Monitor
I have samsung syncmaster 204BE monitor. always
Buddy
Corporate Computer
www.ccl-la.com
Dec 31, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Problem with syncmaster 204bw
Hi there.
unfortunately this is not a driver issue. if possible, test this screen on a different PC/Laptop.
it sounds like a problem with the screen itself - meaning you will have to take it to a service centre, or if its under warrantee - take it to the shop you baught it from.
*** NB note: samsun screens normally carry a guarantee of AT LEAST 3 years, and not only 1 Year.
Jun 17, 2009 | Samsung SyncMaster 204BW LCD Monitor
Open Questions:
Samsung SyncMaster 204BW LCD Monitor Logo
324 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
