Question about Fuji ASK-4000 Thermal Photo Printer
Ask 2000 How do you clean the print head for the Fuji ask 2000? Where is the head located?
2 Suggested Answers
SOURCE: We have a Fuji Ask 2000. We have 2 problems. Our
I am experiencing the same problem but the ripple artifact does not show up on every print. rather on every fifth or sixth one. cant seem to find any support from fuji who asked for my credit card number before i even told them my problem. this item should be still in warranty but fuji would not hear it!.. horrible tech support. hopefully someone out there has found a solution
Posted on Dec 01, 2010
Push power button on front panel and print head carriage zooms behind ink station and crashes.....
Manually try to pull out service station(where print head cleaners located)., feeling very hard?.. cleaning and lubrication required.. Remove right cover., cheat the door sensor., switch on the printer & check for the where is the abstraction?.. If found any paper particles, remove & try.. Still problem persists, service station required over haul & lubrication.. But only professionals can perform this activity., ..
Note: Don't switch on the printer without print heads..Once printer treats no print heads in carriage, it will ask for health print heads for alignment., result you need to spend for full set of print heads.. be care full..
Mar 28, 2015 | HP DesignJet 1050c InkJet Printer
Why is Kodak printer printing bank pages when ink ull
You might have a printer head problem or a technical problem. Go through these steps and make sure that you not low on ink.
1. unplug for a few minutes and re-plug, try printing. if not working,
2. Do a printer head cleaning function, if not working,
3. Remove printer head, clean it, put it back and try again, if not printing, then
4. If you have a spa
re printer head, try that one and see if it prints. if it prints, get a new printer head.
5. If after cleaning printer head you tried a test page and failed to print and printer head is totally dry, first try cleaning the contact area with alcohol solution or use a printer head cleaning kid if you have one but don't invest a lot of time and money in buying cleaning material.
6. If all failed, your printer has a technical problem you cannot resolve, call Kodak support and ask for possibility of a free replacement. They may ask you to upload "data diagnostics" under printer tools and if the problem confirms, they may agree to send you a new replacement. Good Luck.
Oct 14, 2014 | Kodak Office Equipment & Supplies
Giman caranya instal fujifilm ask 2000
pls i need the drivers for this printer ask 2000 for xp
Jul 24, 2012 | Fuji ASK-4000 Thermal Photo Printer
Printer heads errors
switch on the machine wait till error appears on panel, go to the system open internet explorer type IP address enter you can view the entire printer over view.. check which print head showing faulty, ask to replace the head open top cover of the printer open print head cover remove print heads clean print head contact pcb as well as carriage contacts insert print heads back then check for the print head recognition, printer will perform its own priming and all wait till ready mode comes onece ready mode appears.. print heads are OK.. if not replace faulty print head/s.Most of the cases cleaning is enough.
Jan 08, 2012 | HP DESIGNJET T1120 44 Printer
Fujifilm ask 2000 ribbon error e03
please i have ask 2000,how and where can i get the ink and paper?
Aug 30, 2011 | Fuji ASK-4000 Thermal Photo Printer
May 06, 2010 | Fuji ASK-4000 Thermal Photo Printer
I need a replacement print head for my Pixma iP 4200.Can you supply ?
You can obtain a print head from canon .
We dont sell products but we do offer assistance and solutions and ways to fix stuff, for example I'm now going to outline a way to fix your print head without actually having to buy one!
1.) remove the head from the printer (its called an ink well)
2.) Submerger the head of the inkwell into rubbing alcohol or a strong spirit
(the head is the nozzles under the ink well where the ink flows to the paper)
3.) using a straw slowely drop some alcohol on the nozzles which are located inside the ink well (the ones that touch the cartridge) (not the circuits)
4.) place on tissue paper, blot and let dry.
5.) replace and do a few deep cleaning's until it prints.
6.) U may need to clean your waste ink pads as well as u many need to reset your ink counter . If you need to do this click my name and ask directly to me and I'll outline the methods used for you.
In some cases if the above dont work, use this method as a last resort.
1.) Put dome water to boil.
2.) submerger the buttom half of the ink well (ink heads only) in the boiling water until all the old dry ink runs out. (usually 10 - 30 seconds)
3.) dry, blot.
4.) replace in printer and do a few deep cleanings until it prints.
If you have any further questions feel free to ask!
Feb 25, 2010 | Canon Office Equipment & Supplies
How do I clean the print head of a Fujufilm ask 4000? John.
The printhead is a 300 dpi thermal. If you raise the head and can see the glass face, there are 2 rows of heating elements that are used in printing.
As in all thermal heads, do not use any sharp objects to scrape on the head. I usually use a non volitile citrus cleaner or iso alchohol.
The plate beneath the head should also be checked for wear and cleaned to provide positve drive for the stock.
Feb 25, 2009 | Fuji ASK-4000 Thermal Photo Printer
Printing colours
The color cartridge is faulty, you need to replace it.
If it is new ask a refund.
After putting a good cartridge do head cleaning.
Sep 03, 2008 | HP Officejet 5610 All-In-One InkJet...
Open Questions:
See all Fuji ASK-4000 Thermal Photo Printer Questions
Fuji ASK-4000 Thermal Photo Printer Logo
144 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
