26 LCD TV brand name from Best Buy - Insigna
Closed caption is stuck on...Remote can only be used for on/off. Buttons on TV only work for on/off. Is it the mother board and any idea of the cost?
  • 2 more comments
  • Kodee Apr 09, 2008
    Model Number is IS-26LCD TV from Insigna
  • Kodee Apr 10, 2008
    I appreciate you help. My remote only work for on and off...if that is any clue to the problem....
  • Kodee Apr 17, 2008
    Have you had any luck resolving my no sound except from headphones and not being able to use the remote for anything other than on and off?????
    Please be advised that I can not us the remote except to turn the set on and off. No other buttons work nor do the buttons on the side of the TV, again, except for the on and off ones.
    Any suggestions?????
We had the same problem we even exchanged tv for new one, but the closed captions were still stuck. Turns out it was the HD cable box. You need to contact your cable provider and they will help remove captions.
Posted on Jan 22, 2009
  • 3 Answers
I' can't imagine the Geek Squad couldn't tell you over the phone how to resolve the issue. If they can't call the local distribution center in your area and ask for the man in charge.
In the interst of customer service they should take care of you. What model number do you have? I may have some info on the cure.
Posted on Apr 08, 2008
  • OTBMAN Apr 10, 2008
    I'll contact my BestBuy Rep. and see if there is a service code via the remote that can be activated.
    Give me a couple days for a response.
  • OTBMAN Apr 17, 2008
    This may help you out,
    My contact is telling me that
    Page 17 of the NS-LCD26 model manual found on-line at will instruct you on how to turn off the CC.
    Hope this resolves your issue,
My remote control is stuck on Closed Caption. want to get rid of this
On your remote control above circle second from left is button CC
press it.
It will turn on and off Closed Caption
Feb 05, 2015 | Seiki Brand original TV Remote control...
How do you turn on the closed captioning?
U must have the tv original rmote.U have the tv original remote wright?Yes,look at the tv remote carefully for a button that said CC this button sit between the MTS and the DISPLAY buttons second row of buttons near the bottom of the remote.Pushes the tv remote CC button a couples of times u will get like CC1,2,3 so on 1,2,3 so on will give Closed Captioning if the tv programming offer it.If u don't have the tv original remote.Try website like to buy the tv original remote.I have one of this tv too.
Sep 14, 2011 | TruTech PVS31170S1W 17 in. LCD Television
Don't know how to activate closed caption, and cannot find instructions
What is the TV source? For some sources (set top box), you may need to turn on the captions using the menus of the box.
Assuming you are using a source that gives captions that the TV can interpret, if you have the Proscan 26LA30Q remote, press the CC button to toggle through the caption options. Another route is to press Menu (either on the remote or the buttons on the side of the TV) then select the Feature submenu with the left/right arrows. Press Enter (menu when you use the buttons on the TV) then navigate to the Digital Closed Captions option. Here you can set the captions to on and adjust the size, style and color of the captions when they appear on-screen.
If you are using a universal remote, try the CC button. If it doesn't work, try another code for the Proscan TV on the remote. There are some codes that may not control all of the functions of the TV with the remote.
Crutchfield has the manual for the TV on the product site: . The direct link is .
I hope this helps
Aug 18, 2011 | Proscan 26LA30Q 26 in. LCD Television
My brand new Insignia tv has closed captioning that will not turn off. I followed the instructions in the manual but the menu item under settings can not be selected. Please helpw
You can use the TV buttons to get access to close caption by pressing menu. go to features make sure that cc when mute is on.
then use the mute button on your universal remote to toggle to cc1 or off.
May 21, 2010 | Televison & Video
How do we get the closed captioning off
you can turn off using the buttons on the front of the tv go to menu use the vol and channel buttons to navigae go to options and turn cc off
May 06, 2010 | Televison & Video
How to turn off CC without original remote27ms4504
Noway to turn off captioning right away without the original remote.But U can unplug the tv for an hour,tv well reset itself back to original setting.The Captioning will shut off buy itself.Because captioning reqiure CC buttion on orignal remote and must manually turn on and off.
Feb 08, 2010 | Philips 27MS4504 TV
How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
Mar 26, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Televison & Video Logo
497 people viewed this question
Top Televison & Video Experts
