Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Dacor model RSD305. Where is the thermal reset located?
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: where is the thermal fuse on a dacor RSD305 and
What you are describing sounds very much like a piezoelectric 'buzzer' or alarm source. You can verify this by checking the underside of the board; these devices need only two working contacts to sound off. You may find a third which is sometimes used as a 'key' to insure proper orientation.
Thermal fuses are normally mounted to or near the primary source of heat and are used to prevent catastrophic failure of a high powered heating element of some kind. Their failure (blows/opens) when a design temperature is reached and if the common type, about 1/4" in diameter and ~ 5/16" long, these do not 'self-heal.' These can often be identified by a distinctive shape; they have a pointed end of epoxy fill and the other end is actually part of the case.
There is a disk or cylindrical thermal element that is a temperature-sensitive switch using a bimetal disk to interrupt current at its design point and these do reset after cooling.
Posted on Jan 01, 2010
I have a dacor 48"
phone dacor 1800 793-0093
press 2 for parts
they may be able to locate one
Jun 28, 2017 | Dacor ER48DSCH Dual Fuel Range
My Dacor RSD305 duel fuel oven does not work.
you need service
when set the display starts off at min temp
if no heat rise is present it will shut off
check your house breakers first
Jun 06, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
Where is the thermal fuse on a dacor RSD305 and how do you reset it?Is it the round black circle on the back of the board with a small hole in the center?
Jan 01, 2010 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Model# ERD36, Oven Element no heat & no error code flashes.
look for a hi limit thermo in burner box or on back of oven . if it has over heated this would cause this . dacor has a resetable one . it may be located on left side panel will have to be removed . ck elect sch tof location .. mm
Dec 04, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
WAS CONVECTION COOKING FRENCH FRIES IN MY DACOR DCM24 AND HALF WAY THROUGH I STOPPED IT TO TURN THE FRIES. WHEN I CLOSED THE DOOR AND PUSHED START AGAIN, THE OVEN JUST QUIT. NOTHING ON PANEL AND WON'T...
You have a blown convection thermal cutout.
"CONV. THERMAL CUT-OUT
The thermal cut-out located on the left side of the thermal
protection plate (left) is designed to prevent damage to the
heater unit if an over heated condition develops in the heating
unit due to convection fan failure, thermistor failure,
obstructed air ducts, dirty or blocked air intake, etc. Under
normal operation, the thermal cut-out remains closed. However,
when abnormally high temperatures are reached within
the heater unit, the thermal cut-out will open at 302˚F(150˚C)
causing the oven to shut down. When the thermal cut-out has
cooled, the thermal cut-out closes at 266˚F(130˚C)."
We have the full service manual and parts list and you can download them free here:
http://www.microwavedisplay.com/dcm24_sm.pdf
http://www.microwavedisplay.com/dcm24_parts_list.pdf
You can order parts by part number here.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
Oct 04, 2009 | Dacor DCM24 Convection/Microwave Oven
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
Clock is stuck in military time & I can not get it to go back
The newer Dacor ER36D can by switched from standard 12 hour to 24 hour military time mode and back by holding the CLOCK SET button for 6 seconds. That may work on older models as well.
Feb 28, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dacor Wall Oven won't heat - Cannot find thermal reset switch
Open the oven door and unscrew the vented panel at the top. Make sure the oven is off. Atop the electronics in there you'll see a little red button. Push it. Voila.
Dec 24, 2008 | Dacor MCS130 Millennia Electric Single...
Dacor rsd305
yes, you need to open the panel (in the center of the front of the oven when you open the door on the top) and press the reset button, there is a site that gives step by step instructions, but i can no longer find it
Jul 22, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
126 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
