Question about LG WM2277H Front Load Washer
Washing machine is really loud
We took off the back panel and the part that makes the washer spins has leaked some type of fluid out and when you manually spin it, it is very loud. The washing machine works, but this part needs to be replaced. Has anyone else had this issue?
MACHINE WONT DRAIN WATER AND MAKES A LOUD NOISE WHEN U TURN ON SPIN CYCLE
Posted on Jul 14, 2010
  • 343 Answers
It sounds as if the inner water seal has failed and allowed water to get into the bearings.. Rust on the bearings means they are no longer smooth..Hence the noise! Replacing the bearings (and possibly the shaft) is a big job. This is not an unusual problem with front lad washers. Too much detergent will shorten the life of the seal/bearings...Get quotes...Nomess
Posted on Jun 02, 2010
Duet washer making a loud noise on spin cycle, it squeaks on low spin and then when it gets up to high speed, it is really loud. What could this be?
In most cases it is something that is sticking between the drum and the housing. Check inside the boot by the door. If that is not helpful move the drum by hand and listen to see if you can locate the area of the noise.
Dec 30, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Frequent out of balance problem
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Aug 18, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
We have a Maytag Performa PAV2200 Washing machine...lately, during the spin cycle it makes a loud whinning or scraping type of noise during the spin cycle and sometimes during the wash cycle.... we took...
Might be the tub bearing going out. Is she leaking any?
Here is a visual inspect and repair of the tub seal:themobilian_1841.jpgthemobilian_1842.jpgthemobilian_1843.jpgthemobilian_1844.jpg
I used a pipe wrench to unscrew this top portion of the seal (lefty loosey)themobilian_1845.jpgthemobilian_1846.jpgthemobilian_1847.jpgthemobilian_1848.jpgthemobilian_1849.jpgthemobilian_1850.jpgthemobilian_1851.jpgthemobilian_1852.jpg
Those 6 springs are pretty tough to get back on there without the special tool
other than that it all goes back pretty easy.
Service manual and more HERE
Mar 12, 2011 | Washing Machines
Hi, my Bosch maxx 900 front loader washer was in the process of doing a load when a really loud bang happened..now it won't spin..makes all the right noises, but barrel won't move. Took off back panel and...
If you rotate the pulley on the back of the drum does it rotate the drum? i have seen these snap the back of the drum off. also they can have issues with the controller board for the motors which would require a technician to determine.
Oct 24, 2010 | Bosch Washing Machines
Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
Feb 26, 2010 | Amana NAV3330AW Top Load Washer
It sounds like it's coming to get me!! Since it's imbalanced
Check the bearings....when the bearings are gone, it will leak too...
Jan 29, 2008 | Kenmore 43142 Front Load Washer
Spins really fast and loud and is leaking at bottom of tub where shaft goes in
buy a new washer .specifically a direct drive whirlpool,no belt. maytag washers are not what they use to be.
Jan 04, 2008 | Maytag Legacy Series Top Load Washer
LG WM2277H Front Load Washer Logo
335 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
