Question about Dell V305w All-In-One R840635AU InkJet Printer
My Dell v305 inkjet printer will not grab the paper and roll it through. It grabs the paper and continues printing but will not roll the paper through. Is it because it is dirty? That is possible as it was not properly stored while not in use.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First, verify that there is actually no paper jam (open all the doors, take out the paper tray, take out the cartridges and visually inspect). Turn printer off and unplug the printer from all cables (power, USB, etc). Try to hold it upside down and gently shake it so that if there is any paper inside it’s removed. If still it’s not resolved then clean the print head. To clean the print head take a hot water towel with the printer unplugged and the cartridges out, clean it till the time you see there is no ink residue on the towel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 31, 2010
  • faithismymid May 31, 2010
    How do I get to the print head with this particular printer? Can you give a description of what the component would look like?
    There is no paper jam. I did pull a few objects from the area where the paper is inserted. I think something is broken if it doesn't just need to be cleaned, but I'm not sure.
Printer not catching paper
You may have to clean the pick up rollers with alcohol or put a new roller in your printer.
If you have a printer with a tray, make sure it is set correctly for the paper you have installed.
It will try to grab the paper a number of times and will usually give you a paper jam error after a number of tries.
Jul 13, 2010 | Dell 922 All-In-One InkJet Printer
My printer will not grab the paper
I have an R2400 and it is very finicky about grabbing the paper. I have to hand feed sheets of thick matte paper one at a time with just the right amount of pressure and even then sometimes it takes two tries. Make sure you keep the rollers very clean.
May 04, 2010 | Epson Stylus Photo R220 InkJet Printer
After no problems at all, my Dell 926 AIO printer told me that there was a paper jam, but there was no paper stuck in it. Now, it keeps telling me that there is no paper loaded in it, but there is paper...
if you can, check to make sure nothing fell in it. ive pulled thumbtacks and a banana peel out of printers before. also sometimes the little rubber wheels that grab the paper dont grab as good as they once did. sometimes adding more paper or putting in less paper helps. i had this one printer that started not grabbing paper so once in a while i would get a wet paper towel and kinda hold it aginst the rubber things and like print a blank page so it would spin a little, but thats just me
Apr 13, 2010 | Dell 926 All-In-One InkJet Printer
Won't print Dell V305
It seems to be an issue with the Print Spooler Service. Either the service is stopped or not started correctly. Try stopping and restarting the printer spooler services on your computer. For tips on how to restart the Print Spooler service, use the link: http://www.ehow.com/how_2319117_restart-print-spooler-xp.html. Now Reboot your system and try deleting the print queue. It should work fine now.
Good Luck!
-Abhishek
Jan 31, 2010 | Dell V305w All-In-One R840635AU InkJet...
Printer does not "grab" paper but can see parts turning
you have bad rollers. you can try to clean the roller with an alchohol wipe but I doubt it will help much. You need to have the roller replaced or get a new printer
May 27, 2009 | Dell 922 All-In-One InkJet Printer
Dell 922 All-in one ink jet printer paper feed
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | Dell 922 All-In-One InkJet Printer
Hp LaserJet 1100: Runs louder than normal and continuously, BUT will not grab paper and print
Fred shine a flashlight down the paper feed throat and see if the feer roller is rotating when the printer tries to print.
I have had to replace many of the feed rolls and separation pads in this series of printer.
the tires get dirty or worn and feed multiple sheets or none at all. check for obstructions as well-sometimes the black mylar sheet which sits in front of the feed roll gets in the way of the paper path and has to be pushed in place. I have also seen paper pieces stuck next to the paper path switch which is visible after removing the toner cartridge. hope this helps.
Mar 28, 2008 | HP LaserJet 1100 Printer
Lexmark 5250 printer
Before you put papers in tray it must reshaple make separate each other , to delete the message "off the power " on again to continue printing.
Dec 10, 2007 | Lexmark X5150 All-In-One InkJet Printer
Dell V305w All-In-One R840635AU InkJet Printer Logo
289 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
