Question about LG LRFC25750 Refrigerator French Door
Ice build up under the freezer drawer
We find water leaking out of the fridge. In trying to determine the source - we found that ice is building up under the freezer drawer - and it seems to be running down the back of the freezer originating from under the piece of plastic cover at the back of the freezer and then freezing on the bottom of the freezer. When the build up of ice starts to hang over the lip of the freezer it starts to melt and cause a puddle on the floor under the fridge. Is this caused by a malfunctioning compressor, condensor and evaporator? thanks.
aborcass
  • 2651 Answers
SOURCE: Water freezing on the tray section under the freezer drawer.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
mikedurland
  • 481 Answers
SOURCE: My fridge is about
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • or
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 16, 2008
david04928
  • 102 Answers
SOURCE: Build up of ice on bottom of LG fridge freezer
Is it supposed to be self defrost? If so then either underneath the freezer needs to be cleaned. coils if dirty will cause freezer not to work well. I that doesn't help you might have a freon leak which would make it under charged and would ice up like that.
Posted on Mar 15, 2009
  • 66 Answers
water drain clogged !
see this page for a fix, it might suggest a fix to your frig a s well
Avi
Posted on Jan 13, 2011
  • 66 Answers
SOURCE: Ice build up on floor of freezer drawer starting under ice maker
since this problem is discussed over and over on various models, I point you to a detailed manual that shows (with images) how to solve the frozen drain pipe issue. This is the manual by Avi
good luck
Posted on Jan 29, 2011
Hello, can you guys please help me locate what the problem is on my fridge? .. Is building ice on the freezer section.. Thx
If it's building ice on the freezer floor it is likely that the defrost condensate drain is blocked. You will need to remove the drawer, shelves, frozen items, rear panel, rear vent and belt the ice there also until you get the drain unblocked and can force hot water through the hole with a turkey baster.
APPLIANCE 911
Leaking Refrigerators
Dec 08, 2015 | Refrigerators
Ice build-up on the bottom of the freezer drawer
Water on the freezer floor has only two sources, 1) ice maker overflow/leak, or 2) defrost drain plugged. For the first you can turn off the ice maker and shut off the supply water for a few days to see if the problem recurs. If this is the problem determine if the water fill valve leaks or the ice maker is the problem and replace the offender. For the second, thaw out and clear all the ice, paying special attention to the drain located under the freezer (cooling) coil. Then clear the blockage from the drain tube. BE CAREFUL AND DO NOT USE WIRE OR SHARP ITEMS as this can pierce a hole in the drain requiring replacement, not something you want to do or pay for. A turkey baster and hot water are useful tools to flush out the blockage allowing water to drain freely into the defrost drain pan under the refrigerator.
Sep 12, 2014 | Refrigerators
Water collecting inside fridge, under meat drawer
Yes most responses are the freezer drain even if it is in the bottom freezer. If the drain is blocked water will build up anywhere inside your refrigerator only because it has no place to go during the defrost. Defective door seals can also can make the problem much worse. See Leaking Refrigerators I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | GE Profile 22.2 Cu. Ft. Side-by-Side...
My Lg bottom freezer refrigerator, model # LFC21770ST leaks constantly down in the bottom of the freezer and comes out onto the floor. Ice dams build up under the freezer drawer. I take out the ice, but it...
The drain for the auto defrost water is plugged up somewhere.You will need to look at the very back and bottom inside the freezer to see if you can locate it and clean it out.Also you may have to pull the refrig out from the wall and try to get to it from the back.Hope this aleast gets you looking in the right direction.
Jun 29, 2011 | LG Bottom Freezer Refrigerator w/...
A 2 to 21/2 year old Samsung bottom mount freezer RB217ABPN purchased from Costco. Water is starting to collect under the crisper drawers in the fridge section. This is the third time in a couple of months...
You have a leaking water tank behind the crisper drawer. You will need to get back there to determine if the tank is leaking or the water connection is leaking. This will only leak if you close the door and dispense water from the dispenser.
Jun 22, 2011 | Refrigerators
Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice building up in the bottom of the freezer
The water supply line is leaking.Put some paper towels down after you clean up and check real often to back track where leak is coming from,maybe your ice maker is over flowing with water.When was the last time you replaced your water filter?Could be backing up,just replaced mine,it was leaking under the fridge,mine is a Sear's Kenmore,ordered a filter from Sear's,Cost me 50 buck's,My filter is at the bottom front,your's may be inside the freezer.
Apr 13, 2017 | KitchenAid KBLC36FKS Bottom Freezer...
I have a whirlpool Gold Model GR2SHKXKS01. My problem is ice build up under the bottom tray of freezer and when fridge defrost the tube is frozen solid and creates this build up. After cleaning all the ice...
I have Ice build up under the tray in the freezer which makes water run into my refig and makes a mess what would cause this is the evavorator motor out?
Jun 03, 2009 | Refrigerators
FREEZER HAS ICE BUILD UP AND FRIDGE WON'T STAY COLD. ? what causes this and can i fix it?
Bad news, it appears unit is short on gas leak,,,,,Because of this the temp. sensing device over reacts causing the frig to constantly run,,,,also poor door seals do not help,,,,due to costing of repair its better to replace the unit. Water thing bit of a mystery,,,,,could be blocked defrost drain,,,,refrig section of cooler section and just below this is a small drain hole of some description, get a tube or straw and blow down this to clear blockage,,,,,difficult without seeing but hope to be of help,,,,,,,,,,,,,Barry
May 31, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidiare PLHS39EESS9 Ice build up in bottom of Freezer
I had the same problem with my Jenn-air side-by-side
Your freezer has a defrost cycle and when the freezer temp is set too cold, your drainage pan and tube freezes up (behind the back panels in the freezer) and when that gets full it spills over too the bottom of the fridge and keeps building up until you notice.
  • Un-plug fridge and put your food in coolers or another fridge.
  • Defrost the freezer, remove the ice from the bottom.
  • Remove the back panel/s (in the freezer).
  • Check the drainage pan. If it is iced up, you'll have to carefully remove the ice and check the drainage hole.
  • If the hole is iced up, so is the first 1-2 inches of the plastic tube leading to the main drainage pan behind and under the fridge.
  • You can use a hair drier to speed up defrost.
  • To defrost the hole and tube I used round ended metal (nut pics or beater attachment ends- avoid sharp objects) heated up in boiling water and gently forced down into the hole and tube until defrosted.
  • Check flow(by pouring warm water) down and looking behind and under fridge(with flashlight) to see if flowing into main drainage pan.
  • Turn up your freezer temp and check with a thermometer. Your freezer temp was probably set too cold
Mine is going on 5 months with no problem. If this continues, it might be the defroster.
Good Luck!
Mar 22, 2009 | Frigidaire PLHS39EESS Stainless Steel
LG LRFC25750 Refrigerator French Door Logo
180 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
