Question about GE WBSR3140DW Top Load Washer
Leaking from the bottom - GE WBSR3140DW Top Load Washer
  • 333 Answers
Sounds like one of the hoses came loose. At the pump or the tub. Does the water keep coming in? could be the hose for the pressure switch. Or coming out of the inlet valves.
But id say hose.
Posted on Jun 02, 2010
Washer
No offense, but I think it's time for a new washer. The only thing that comes to mind for leaking would be a broken hose. Is it leaking out of the bottom bottom or like the bottom of the door?
Jul 06, 2013 | Washing Machines
Hayward sand s166t. leaking from bottom
Are you sure it is leaking from a spot "Originating" at the bottom? Many times this is what is seen, but the water is actually traveling down the side.
If at the bottom, you either have a cracked tank, or the drain cap is loose, missing the cap gasket or it is on "Cross Threaded"?
But... most likely from experience, it leaking at the valve clamp.
Nov 17, 2012 | Hayward S166T Pool Filter System w1 HP...
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Frigidaire dishwasher leak
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Sep 02, 2012 | Frigidaire Dishwashers
Washing machine is leaking from the bottom of the machine and leaking after the wash cycle inside. 622797 style no. The machine leaks during the rinse cycle from the bottom.
Washing machine is leaking from the bottom This video will show you how to find the leak on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jun 07, 2011 | KitchenAid Washing Machines
Badger 5 is leaking from bottom of unit... is this repairable? Thanks Chad
If it is leaking from the bottom and not from the top and running down the side then it is only repaiable by replacing the disposal, If it the top leaking and running down the side, then it can be rpaired by replacing the rubber gasket on the top.
Nov 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: leaking out the bottom...
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking from bottom ofoasis top loading machine
you may not be leaking out the bottom. Your stand pipe may be clogged. If the stand pipe has a slight clog in it, the stand pipe will over flow, and the water "looks" as if its leaking from the bottom... These pump faster than your old machine, so the pipe will back up faster... hope that helps
Jul 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
71 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
