Question about Epson TM-U220 Matrix Printer
Epson u220b printer
Keep getting paper out error. I put a new roll in, went right back to the same error. Tried a different roll, same thing. Reset printer, prints fine then goes back to paper out error. I checked for paper jams, none. Can you help?
  • suyop live
    suyop live Jun 15, 2008
    same here, even after the windows test page it does the same error.
  • getthechad Mar 04, 2009
    I have three Epson TM-U220 printers and wire was off of all three of the cutters. After I saudered the wire back on... now it gives me a "paper out" error after one print.
  • Epson Master
  • 1,879 Answers
Service for that unit - call the manufacturers tech line and they'll give u service center nfo - it it's still under 2 years - repair will be free of charge
Posted on Jun 14, 2008
    Problem Solver:
  • 16 Answers
If cutter issue , the printer will show the error light single blinks...and paper our shows the defective of paper sense switches....
Posted on Dec 11, 2012
Why does it just print once, then the second time it prints half and shows an error?
This happened to me. What I did that worked was first unplug the power cord. Open up the printer where you can access the ink cartridge. Check for any paper jam or debris. Clean that out. move the cartridge all the way to right and slide it back and forth about 5-8 times. Plug the cord back in and try to reprint again. I hope this help.
Jan 29, 2016 | Epson Impact TM-U220B Thermal Printer
Epson u220b printer will feed paper but will not print
may you put the paper in wrong order just turn the paper up side down and then check if ok nothing to do if not u have problem with thermal head or head alingment
Jul 14, 2014 | Epson TM-U220 Matrix Printer
Paper Jam Error
Epson RX595 Photo All-In-One Printer
Paper Jam Error
Dec 28, 2013 | Epson RX595 Photo All-In-One Printer
Printer jamed after putting in more paper and accidently pushed the power button off. Will not respond to anything I have tried.
Reset your Printer by following these steps for your Printer Model:
EPSON Stylus Color 900, 980
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button, You will see blinking INK OUT led.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons turn on printer.
EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led.
Feb 27, 2011 | Epson Stylus Photo 785EPX InkJet Printer
Paper loading error
hi the sloution to the problem is that to go ahead and try to reset the printer and it will definetly work ,
if you get stuck on some problem try to get in touch with me on fixya
Jul 22, 2009 | Epson Stylus Pro 9800 InkJet Printer
Reload Paper constantly shows up
This printer is very finicky about paper loading. I see this error most commonly when using auto-cut roll paper. If the paper edge is not cut perfectly straight, and it is not inserted into the printer perfectly strait, it will give you an error. When it does this, you can simply load the paper and press "cut" instead of "pause" when it says "press pause" and it will cut the paper straight. You can also set it to "Roll Paper Manual Cut" and load the paper, then set it back to "Roll Paper Auto Cut."
Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
My epson r1900 won't load a roll of canvas through the roll paper feeder. I put the roll of printable canvas on the roll mounts but no matter what I do it won't feed into the printer.
After talking for many minutes (thank you Skype!) to the Epson service guy I am now able to load a roll of canvas. The trick is that the paper must be firmly against the right side (looking from the front) of the feed slot and must have some slack going in. The only way I can accurately meet these conflicting requirements is to put the roll in the roll guides on the table behind the printer and feed the paper into the slot holding it on both edges. When the paper is blocked be sure to pay attention to the right side and have it as firmly as possible agianst the right side of the slot and push enough into the slot so that it bowes up a bit. You will feel the printer gently grab the paper. Immediately let go, don't fight it.
I leave the roll on the table, but after this point you probably can mount it on the back if you need to.
In case it is not clear: after printing tapping the roll botton will mark the cut line and feed the paper out. After cutting tapping the button again will roll it back for the next print. Holding the roll button will eject the papaer out the back.
Apr 26, 2009 | Epson R1900 Printer
Borderless error with 44' paper
Are you setting up a custom paper size each time? Check out page 91 of the 9800's user manual... it has a table of recommended custom paper widths for borderless printing.
Feb 23, 2008 | Epson Stylus Pro 9800 InkJet Printer
Epson TM-U220 Matrix Printer Logo
766 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
